Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 02-26-2014, 10:06 AM   #1
Clrussell
Clrussell's Avatar
69 4x4 burb daily driver
Hey guys, I've been around here a while just never said much. Thought I would start a thread on my burban. I've had it about about 6 months and drove it around every now and then. Well I sold my duramax and have decided to do a few things to the burb and drive it. I traded into it this suburban, I've had my 71 truck for about 10 years now and love these style trucks.
Anyway to get ya up to date on it. It's a 69 k10, 4x4, 4 speed, Rockwell t-case, factory 292.
Had 350 swapped into it which runs great. New fuel tank and lines, new dash pad, new rubber floor mat to the cargo area, all the gauges work except speedo.
Im trying to do this as cheap as possible so I'm trading for most of the parts I have.
So far I've traded for camper special 14 bolt/ dana 44 combo, got a free 700r4 and mating t case (208?) and I've swapped for a 454 with 50k on it.
The 700r needs rebuilt so I plan to do all the upgrades to it to try and make it last. Is it possible behind a stock 454 with an rv cam? It will be towing my boat about 100-200 miles every weekend and drove to work daily. I don't plan on wheeling it or beating on it just driving it.
I've bought disc brake brackets from ruff stuff industries for the 14 bolt, and the power brake booster adapter from captain fab on here.
How direct is a 454 swap where the 350 is currently? I plan to keep the 350 for the wife's 62 her grandpa gave her.
Here's the pictures if they will work, I'm probably going to post 90% of everything from my iphone so bear with me
61 apache
Clrussell is offline   Reply With Quote
Old 02-26-2014, 10:07 AM   #2
Clrussell
Clrussell's Avatar
Re: 69 4x4 burb daily driver
Hmm not sure how to post more than one pic at a time
61 apache
Old 02-26-2014, 11:34 AM   #3
Bigdav160
Bigdav160's Avatar
I had a 402/700R4 combo in my swb '67 stepper. It worked great. Two years later I decided to change things up a bit and when I disassembled the transmission, I was surprised at the amount of damage. I've since decided that the 700R4/4L60/4L60e doesn't really like the torque of the big block. Long term it's not the best solution.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 02-28-2014, 01:45 AM   #4
Average Joe
Average Joe's Avatar
Cool Burb. X2 on not using the 700r4. I know guys put em behind bb's but I wouldnt take a chance. If you can get over the initial cost of the stand alone computer/controller, the 4l80 is a great choice. Im not much of a 4x4 guy but I think with different mounts and towers that 454 will drop right in. If its anything like its 2wd sibling you might consider grabbing the clamshell mounts from a 70s or 80s rig. Obviously a tranny mount would have to be sourced or fabbed up.
1967 C10 Suburban 454/TH400/3.07's
An Average Joe and His 'Burb:
http://67-72chevytrucks.com/vboard/s...d.php?t=775843
Average Joe is offline   Reply With Quote
Old 02-28-2014, 08:40 AM   #5
Clrussell
Clrussell's Avatar
Thanks guys, I guess I'll just put the 700r in the shed for a later project maybe. I plan to do some sort of larger scale swap in the future so I'll probably just leave it 454 4 speed for a couple years. How good is the Rockwell t case? Boat anchor or leave it until I do a swap?
61 apache
Old 02-28-2014, 10:32 AM   #6
magicoolbus
magicoolbus's Avatar
Looks like you have a Rockwell t-case. Good in the day, but a 205 is the better choice. If your burb is anything like mine, you also have closed knuckle front axle. Also good in the day, but better choices from the 70's. Going big block, I would suggest getting a roller from the late 70's or early 80's and make a swap of the running gear.
JB from AZ
1969 Chevy Sub K10
1957 Chevy 3200
1962 VW Beetle
1957 Willys CJ5
magicoolbus is offline   Reply With Quote
Old 02-28-2014, 01:15 PM   #7
Clrussell
Clrussell's Avatar
I've already got the dana 44 and 14 bolt 3/4 ton combo waiting to go in. Getting away from the closed knuckle and drum brakes. I know the 205 is top choice, might try and find one anyway and swap it in. Didn't want to unless I really needed to.
61 apache
Old 03-22-2014, 09:26 PM   #8
Clrussell
Clrussell's Avatar
Finally got around to workin on the burb last couple days, I started last night and pulled the front clip and a few things off the engine to prepare for the 454 swap.
61 apache
Old 03-22-2014, 09:28 PM   #9
Clrussell
Clrussell's Avatar
After I pulled the bumper off
61 apache
Old 03-22-2014, 09:44 PM   #10
Clrussell
Clrussell's Avatar
Where I quit last night
61 apache
Old 03-22-2014, 09:45 PM   #11
Clrussell
Clrussell's Avatar
Got it out and steam cleaned the frame/ engine bay
61 apache
Old 03-22-2014, 09:46 PM   #12
Clrussell
Clrussell's Avatar
Forgot picture
61 apache
Old 03-22-2014, 09:48 PM   #13
Clrussell
Clrussell's Avatar
Got the 454 in after 3 tries, it's a tight squeeze
61 apache
Old 03-22-2014, 09:49 PM   #14
Clrussell
Clrussell's Avatar
Forgot picture again
61 apache
Old 03-22-2014, 09:52 PM   #15
Clrussell
Clrussell's Avatar
Where I got to tonight. Got mostly everything together. Headers I ordered are a no go so I'm probably just going to put the manifolds on it so I don't have to mess with the clutch linkage. Hopefully get it running tomorrow if I have a couple hours to work on it.
61 apache
Old 03-22-2014, 10:16 PM   #16
franken
Love the look of the BB in there and sure it'll be fun. Any guesses on gas mileage?
franken is offline   Reply With Quote
Old 03-22-2014, 11:23 PM   #17
Clrussell
Clrussell's Avatar
If it gets 10 I'll be happy. My 71 averages about 6 so I'm not picky on fuel mileage
61 apache
Old 03-22-2014, 11:30 PM   #18
Clrussell
Clrussell's Avatar
Better picture pre accessories
61 apache
Old 03-22-2014, 11:31 PM   #19
Clrussell
Clrussell's Avatar
Forgot pic
61 apache
Old 03-23-2014, 10:35 AM   #20
thelonerife
thelonerife's Avatar
Good progress!!
thelonerife is offline   Reply With Quote
Old 03-23-2014, 08:04 PM   #21
Clrussell
Clrussell's Avatar
Originally Posted by thelonerife View Post
Good progress!!
Thanks, hope to have it running in the next couple days. Have to try and find manifolds..
To anyone reading. I need a ps bracket for my 454
61 apache
Old 03-24-2014, 12:22 AM   #22
Clrussell
Clrussell's Avatar
Didn't have much time to work on it today, got the plug wires routed and trimmed. First time I've actually took the time and made my own wire set.
61 apache
Old 03-24-2014, 07:49 PM   #23
Clrussell
Clrussell's Avatar
Ran into a minor/ major road block tonight. I've got to move the entire drive train forward an inch. Already holes in the frame by the engine crossmember. So I'll just have to slide everything and re still holes for the transmission crossmember. In done messing with it for tonight..
Anyone have any header/ exhaust manifold advice? The passenger manifold will work great, the driver side is a little different and exits at the 3rd port instead of after the 4th. Driver side is a no go..
I didn't take any pictures tonight, to frustrated.
61 apache
Old 03-26-2014, 08:53 PM   #24
scotto0609
Junior Member
Hooker headers,I believe super competion.
scotto0609 is offline   Reply With Quote
Old 03-26-2014, 09:02 PM   #25
mud.man.rj
mud.man.rj's Avatar
Nice project, cool on the big block will be nice to have the torque to move it down the road. Your moving pretty quick, will be watching the build.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline   Reply With Quote
