Aftermarket shoulder belts ?
Anyone using aftermarket shoulder belts with stock seats in a Suburban ? We have 5 kids with us at times and booster seats need shoulder belts to be used properly. That leave our little guys with just a lap bet. Any input would be great.
Mario
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
What?
Re: Aftermarket shoulder belts ?
I don't have them, but I have heard that S-10 shoulder belts work well in the 67-72 trucks.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
![]() Join Date: Sep 2010
I'm very pleased with the shoulder belts and center seatbelt in my C-10 pickup which came from Morris Classic Concepts: . . . . |
C10 Club Tennessee
Mario, I'm using the 88-98 style seat belts and for just a little modification they appear to work great.
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 |
![]() Join Date: Jan 2014
Mario, were you able to figure anything out here. I just acquired a project and my wife and three daughters will be riding in it, with use of boosters. I was hoping as well to to utilize shoulder belts in the middle and rear seats as well. If you were able to find something if you could post pictures on how you mounted the rear shoulder belts that would be great. If I find something I will do the same. Thx
The seat belts from Morris Classic Concepts look nice but it would be over $1000.00 to belt up the burb. I am interested in the 1988-98 belts option. I am actually thinking of having 1967 belts re-webbed into factory shoulder setup. If I am going to be spending $1000. I have 6 passenger's worth of 67 belts here...
I will post picture of whatever I end up doing.
Slots go on anything!
Check out Wesco performance. They have some retractable belts, and you can get the GM logo in the buckles. Seems like it was about $85 per setup in an optional color when I was looking for my crewcab. I remember about $450 for 4 retractable shoulder harnesses and 2 lap belts shipped.
1974 Jimmy- 5.3/4L80e/NP241 |
C10 Club Tennessee
Mario, the 88-98 seat belts that I have need a spacer, but I believe they will work. The bolt hole is two inches taller than the bottom of the plastic on the belt. I just used a 2 inch piece of square tubing and a longer Grade 8 bolt to go to the floor.
Still plays with trucks
The second row shoulder belt system from the late square body Suburban fits very well size wise with just minor mods since they bolt to a flat floor where our floors are slightly angled. I don't know what year they started for sure but I know 1989-91 have the shoulder belts and the 1986 has second row lap belts.
The bolts in the shoulder belt anchor on the pillar are a different thread pattern so this will have to be addressed as well. I just found some grade-8 bolts of the right thread pattern and built some tube spacers & heavy flat washers to make them work right. Putting in a heavier reinforcement with the newer large bolt thread pattern would probably be a better idea and I may do that in the end on mine since I need to add the C-pillar reinforcements anyway. On your second row there isn't a factory shoulder belt anchor reinforcement in the C-pillar like there is for the front seats in the B-pillar so something will have to be added so the anchor bolts don't pull out. I have them for my 67 but haven't had the time to build the angled spacers yet to give you any pictures. Hopefully this spring if it ever stops snowing. ![]()
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
I put in a 4 point harness on the rear seat for my kid. Got a pair of them off of ebay for $40 and safer than a 3 point.
![]() Join Date: Jan 2011
I got my shoulder belts for my 66 from these folks. http://www.andoverrestraints.com/ Nice stuff and they offer the correct type of retracter for a child seat or booster.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
