Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 03-01-2014, 06:08 PM   #1
HeavyMetalThunder_81
HeavyMetalThunder_81's Avatar
Has anyone done anything like this?
The previous owner of my '79 quite brutally hacked up the dash where the radio mounts to fit a $30 Pep-boys special aftermarket radio. I'd like to put a stock two post back in. My idea is to find a truck in a junkyard that still has a good dash and, as carefully as possible, cut out the area I need for the radio then place it over the hacked hole in my dash and rivet it on. This is the only way I could think of fixing this other than replacing the whole dash. Does anyone else have any ideas?
-Jonny B.
1979 Chevrolet K20 Scottsdale: GM350/SM465/NP208
1979 Jeep Cherokee Golden Eagle: AMC360/TH400/D20
1999 Dodge Ram 2500 Larime SLT: Cummins 5.9L 24v/47RE/NP241
HeavyMetalThunder_81 is offline   Reply With Quote
Old 03-01-2014, 07:48 PM   #2
Zane M
Re: Has anyone done anything like this?
I'm sure plenty of people have repaired radio cut outs. I do think that most weld them in, but riveting will work. It may be a little harder to cover up on the right side with the bezel however, due to the proximity of the bend in the dash
Zane M is offline   Reply With Quote
Old 03-01-2014, 08:05 PM   #3
_Ogre
_Ogre's Avatar
unless your truck is a 100 point concourse restoration, i'd make a nice single din adapter for it
single din head units will be around for a long time, can be found for cheap and can be bought with all the latest technology
shop air compressor timer
Old 03-02-2014, 06:57 PM   #4
piecesparts
Parts and more parts
piecesparts's Avatar
I took aircraft aluminum plating. It is thin, but hard. I cut out the shape of the lower area that the radio sits in and then cut the new panel for my radio. I painted the aluminum panel to match the dash paint, since it was black--it was easy. The radio is then mounted into the aluminum panel and then the whole assembly is mounted into the dash with screws.
Frank
piecesparts is offline   Reply With Quote
Old 03-02-2014, 07:20 PM   #5
Well, that works for me. I have access to plenty of aircraft grade aluminum lol. So, with the gauge bezel installed, can you tell that the patch panel is there?
-Jonny B.
Old 03-02-2014, 07:30 PM   #6
piecesparts
No, the thin panel blends into the dash and it is cut to fit the shape of that lower area, so it covers the whole area and becomes part of the dash. The aircraft aluminum is hard enough that it can be cut to a very thin area, if need be and not fail or bend.
Frank
Old 03-03-2014, 11:43 AM   #7
nekkidhillbilly
just weld a flat plate of steel in and drill/cut the holes for a shaft style. it will be stock but have a horrible oem radio too. that or you can put a new shaft style from retrosound or casmfg and spend 300 bucks. since its cut me id put a good new din radio.
nekkidhillbilly is offline   Reply With Quote
Old 03-03-2014, 09:21 PM   #8
I might put a regular DIN stereo in it but the dash is so hacked out that a regular DIN stereo doesn't even fit...plus I like the full feeling of driving a classic truck with a classic looking stereo. I will, however, be using a newer style post stereo similar to the RetroSound from LMC with CD changer and iPod hook-up.
-Jonny B.
Old 03-15-2014, 04:42 AM   #9
BigMike
BigMike's Avatar
Was it this bad? I think he must have worked for the road dept and used a jack hammer on it.
I just replaced the whole dash, here it is now.
BigMike is offline   Reply With Quote
Old 03-15-2014, 08:27 PM   #10
Yea, mine looks a little similar to that lol. But, thanks to Manimal, I have this to patch in. Thanks, Lance! And I sourced a new/used bezel from eBay. Score.
-Jonny B.
Old 03-20-2014, 08:28 AM   #11
motornut
78K & 79C Jimmys
motornut's Avatar
thats the best way,may want to check the fit before you install it,may need a trim?
I had to remove the lower "lip" but prob cause its a bigger stock CB unit with cass
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 03-21-2014, 05:16 AM   #12
RoughKuntry
RoughKuntry's Avatar
I think yall would like what I am doing to the 1980 Big 10, I love how the 1972 Chevy trucks have the stereo in the middle of the dash so I have been trying to get my Boss Deck to fit right over the ash tray. Only problem is after I have it wired up, I cant hear anything out of my 2 Studio 54 4 way speakers. anyone have the Boss 612ua wire up photo?
RoughKuntry
73 GMC 25 HUNDRED :Sold
79 GMC High Sierra 4x4 (Ma-Duece) :Sold
99 Chevrolet LS 4.8l/5 Speed Manual 4x4 :Selling
88 Chevrolet Burban 2500 4x4 :Buying
RoughKuntry is offline   Reply With Quote
Old 03-23-2014, 02:00 PM   #13
nekkidhillbilly
you could just put sheet metal over the cut part. it would be hid by the bezel.
Old 03-24-2014, 11:08 AM   #14
That's basically what I'll be doing with the patch panel I got from Manimal. Straight sheet metal won't have the indent needed for the radio to sit in the right spot.
-Jonny B.
Old 03-24-2014, 01:05 PM   #15
nekkidhillbilly
i dont think it would matter once all the trim was on it.
Old 03-25-2014, 02:36 PM   #16
suspect
suspect's Avatar
Mine was almost as bad as BigMikes. That dash bandit must get around! I took some measurements off a friends 67 and welded up flat stock and redrilled the holes.
Daniel
68 C10 Build http://67-72chevytrucks.com/vboard/s...d.php?t=503594
Romans 10:13 Everyone who calls on the name of the Lord will be saved.
suspect is offline   Reply With Quote
