03-03-2014, 05:51 PM | #1 |
Carpe manana
So this is what a rolled K5 looks like
I guess a roll bar can be useful. The Hickey roll bar (not the one in the pic) seems a little puny but better than nothing I imagine...
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
03-03-2014, 07:38 PM | #2 |
Proprietor of Dale's Corner
Re: So this is what a rolled K5 looks like
How depressing, I guess anything that helps keep space between the head and asphalt is a good thing....
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
03-03-2014, 09:05 PM | #3 |
I've seen one without a roll bar go tires up. The windshield folded completely flat on top of the driver and passenger without putting up any kind of resistance. Yes, they were hurt bad. So even a small 4-point roll bar as seen in the picture is a life saver if not a truck saver.
03-04-2014, 02:15 AM | #4 |
Active Member
That's sad to see Deadhead. Is that yours? Where u in it? Everyone OK?
Makes me wanna look into a roll bar. Anyone have suggestions on where to find one? Still coming to NM this month? Morey
72 Blazer, 70 El Camino SS, Anniversary HD FatBoy, 2012 Ram 3500 4WD Dually, 17 Dodge Challenger, 80 Vette, 65 Chevy 3/4 Ton 4 W/D Pickup and some more. Wife: 06 GMC Duramax 3500 4WD Single Wheel, 2016 BMW X3. Next: Rust removal on my Blazer. Thinking of putting a 50 Chevy cab on a 76 Chev 4 WD pickup. Members Met: Aldtime, DeadheadNM |
03-04-2014, 05:19 AM | #5 |
Damn that sucks. The roll bar more than likely saved their live. Hope everyone is ok. You can buy a kit on eBay for 300-500. Hard to find the stock rollbars anywhere.
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks. |
03-04-2014, 05:51 AM | #6 |
Amazing how many you see running around with nothing but blind faith that the window frame will protect them.
Chevy GMC Trucks Find Of The Day https://www.facebook.com/ChevyGmcTrucksFindOfTheDay or http://ChevyGMCTrucks.com |
03-04-2014, 09:00 AM | #7 |
Carpe manana
Hi Morey - Thanks, not mine just pics I scrounged on the web. Not sure this helps but back in September a guy listed two Blazers and some parts. He had a roll bar - not a vintage bar as the OD of the tubes was much larger. He was letting that go cheap. Not sure I'll make it down in March but I will let you know. I actually like the clean look of no roll bar but my Blazer has a 4" lift and the higher center of gravity makes me think adding one as a measure of safety is a sensible idea. Pete
03-04-2014, 09:22 AM | #8 |
Glad it wasn't Yours. A simple roll bar helps even in a road rollover. The window frame is weak to say the least. Years of internal rust leaves most of them pretty thin to begin with. I will be putting one back in this summer. The one that was in wasn't built very well and I believe was just schedule 40 pipe. Wasa six point though but blocked the glove box door and the p o cut it to be able to get it Open. I have a new one but the old spid is damaged on the stock one. I need to get one of the repro ones off The guy on here that makes them. I think the one on eBay that look like the one smittybilt used to make would work out prett good. I've thought about hooking the upper tubes to the windshield frame but it might be too much for it to handle off road when the body flexes.
03-04-2014, 01:18 PM | #9 |
Any one have a picture or any info on what a rolled K5 looks like with the top on?
03-04-2014, 03:00 PM | #10 |
Active Member
Thanks Hombre. I'm gonna look into one.
By the way, what's the difference between the two tops everyone's talking about. Double versus single wall. Is the double an insulated version?
03-04-2014, 07:25 PM | #11 |
I've seen that too. Just picture the same picture posted in this thread with jagged, broken fiberglass (or SMC) and more broken glass laying everywhere. The hard tops might buy you another half second to duck. By no means will they provide any sort of protection during a roll-over.
03-04-2014, 08:13 PM | #12 |
Carpe manana
You bet. There are two versions of the K5 top; an early version (continued through 72) that was what I like to think of as a "double hull" similar to that on a boat with inner/outer layers (double wall), and a later version (beginning 71? def in 72) that had a single layer (wall). Double wall tops attach with bolts along the undersurface of the bedside so if you have panels (like a CST) these need to be removed before the top can be unbolted. A single wall top has top has top bolts so panels don't need to be removed, has additional reinforcement/construction to prevent the "sag" seen on 2x wall tops, and has dome lights. Post pics of your top from the inside and we can see which you have. Pete
03-04-2014, 08:15 PM | #13 |
Carpe manana
Here's a burning Jimmy:
03-04-2014, 08:16 PM | #14 |
Carpe manana
Not sure what happened to this Jimmy - maybe plowed headlong into a clown car
03-06-2014, 03:17 AM | #15 |
Currently Blazerless
Are you sure you guys want to see this????
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C Last edited by BLAZERMAN; 03-06-2014 at 04:38 AM. |
03-06-2014, 03:18 AM | #16 |
Another
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
03-06-2014, 03:19 AM | #17 |
Ouch!!
03-06-2014, 04:51 AM | #18 |
stuck, blew it up n burned it to the ground trying to get out......?
03-06-2014, 05:02 PM | #19 |
It looks like there is a line coming out of the winch maybe electric fire ??
ugly business either way |
03-06-2014, 05:05 PM | #20 |
Blazerman if those photos aren't reason enough to put in a roll bar I don't know what is. Scary stuff...
03-06-2014, 05:06 PM | #21 |
03-06-2014, 07:11 PM | #22 |
Dibs on the skid plate!
03-06-2014, 09:28 PM | #23 | |
Carpe manana
03-06-2014, 09:31 PM | #24 |
Carpe manana
Rob what's the story on the flipped Blazer? Are you one of the guys standing next to it?!
03-07-2014, 05:02 PM | #25 |
Nope it wasn't me Pete...just some pics I found somewhere on the Internet years ago. I wish I knew the story behind it....I'm betting the outcome wasn't good for anyone that was in it.
