highway noise
So last Sunday I was driving back from the Pomona swapmeet and I noticed a type of groan noise from my suburban at highway speed. It's not a clunk or grinding noise. It sound familiar to tire noise but it goes away if I let off the throttle or if I'm above or below about 1800 rpm. I can't tell exactly where it's coming from. I was thinking either water pump or power steering but I'm not sure. Anybody know what it can be? Also I noticed that the hose from the pcv to the bottom of the carb was collapsing when I give it throttle. I replaced the pcv but am not sure if that can be related in any way.
![]() Join Date: Jul 2010
Re: highway noise
I would say if it is the PS pump, during turns, the pump would groan and make the noise you are hearing but in a louder fashion. Do you have a fan clutch between pump and fan? After the engine is at temp and engine is turned off, grab fan and see if there is any resistance to turning it.
JB from AZ 1969 Chevy Sub K10 1957 Chevy 3200 1962 VW Beetle 1957 Willys CJ5 ![]() |
Re: highway noise
I can describe the sound as similar to a heavy fan with the clutch but I'm running electric fans.
Re: highway noise
Exhaust leak in just the right spot or bad u-joint?
Alex V. ------ 1967 C10 Suburban, 350/NP435, Green/Green, PS, PB, HD cooling, charging, shocks, and springs. 1985 GMC C3500 SRW, Sierra Classic, 454/TH400, white/blue. |
Re: highway noise
I experienced something similar a couple of weeks ago..... at about 70 it was as if I was driving on a rumble strip and would stop if I backed it down..... When I put my burb together, I had converted to a one-piece driveshaft and had not checked the u-joint angles..... Proper angles should be less than 3 degrees on each u-joint and the 2 u-joints should have the same # of degrees.... I addition, the trans tail shaft and pinion shaft should be on parallel planes.....It turned out that all I had to do to achieve these specs was put a 5/8 inch spacer under the trans mount and OH WHAT A DIFFERENCE!.....
To fully grasp the concept, do a google search... lots of diagrams and such! |
Re: highway noise
agree, mine was pinion angle only at high speeds corrected and no problems since
current project: 1964 chevy II Wagon 1956 3100 1972 c10 burb bagged 1962 GMC burb 1963 c10 burb 1966 c10 burb 1995 chevy lowerado 5/7 static drop daily driver 1963 c10 step side 1965 super sport impala 1967 c30 |
Re: highway noise
Update. I ended up servicing the rear end a couple weeks ago. It was very very low on gear oil. There were 4 small pieces of the clutch at the bottom of the dif. The gears looked fine and after topping it off it still made the slight scraping sound. I have had it parked since then and noticed a leak coming from the front of the rear end where the driveshaft yolk attaches. Could the seal be what's making the noise? Possibly scraping on the rotating yolk? Also will I be able to continue driving it if I take care of the leak or is it gonna blow up on me due to the little pieces of clutch I found.
Re: highway noise
I replaced the rear pinion seal and no more leak. I drove to work today and I still hear the sound. But it sounds more like a whistle coming from the drivers side engine by the brake booster. It's really hard to tell because I only hear it while driving. It won't do it in park. It comes in right around 1500 rpm and goes away by 2000rpm. Any ideas?
