Old 03-11-2014, 12:56 PM   #1
chewiebarker
chewiebarker's Avatar
What is appropriate wheel hole size for K20 Suburban?
I bought some 16", 8x6.5 lug, steel rims off of CL from a later model truck and they were REALLY tight going over the front 4wd hub of my '71 3/4 ton Suburban(scraping along in fact). I haven't even tried the rears yet.
What is the appropriate HOLE size for rims on 3/4 ton Suburbans?
Also, could the hub be damaged by having the rim up tight against while driving around?
My prior wheels had a decent gap between the inside rim and the hub. Now there is no space whatsoever. Will too much force be transferred to the hub now when driving? If so, I will ditch the wheels.
Thanks!
1971 K20 Suburban
2012 LS1500 4WD Suburban
2003 Honda Accord LX V6 (don't tell anyone)
MY 'BUILD' THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=618915
chewiebarker is offline   Reply With Quote
Old 03-11-2014, 01:16 PM   #2
4shongo
Re: What is appropriate wheel hole size for K20 Suburban?
Just grind down your hubs a little (kind of just bevel the end some and keep checking to you have a good fit). That is what I did (took about 10 minutes per side). Lots of guys have to do it to get aftermarket wheels to fit. Check out the wheel section too and you will see more posts about it. Good luck
4shongo is offline   Reply With Quote
Old 03-13-2014, 10:45 AM   #3
chewiebarker
The spare that came with my suburban appears to have a 4 and 5/8th inch center hole and fits nicely over the hub. However, rather than keep screwing around looking for the right fit, I picked up a set of 16" Ford rims that accept 3/4 ton 12" hubcaps and have a wide 4 and 7/8th inch center hole.
Thanks for the tip though. I would never have thought to grind the hubs down. Do you paint them afterwards or just let them rust up?
1971 K20 Suburban
Old 03-13-2014, 11:00 AM   #4
4shongo
I painted the hubs and the calipers with the good Caliper paint after the grinding session. Nobody can see the hub when the wheel is on anyways.
Old 03-13-2014, 11:52 AM   #5
chewiebarker
Thanks!
1971 K20 Suburban
wheel size
