Old 03-18-2014, 04:51 PM   #1
1970C20L9H
1970 c20 l9h 6l90e
Hello.
A few weeks ago I blew the motor on my 1970 Chevrolet C20 so you know what that means.
I just bought a 6.2L L9H with 6L90E complete pullout with 7,000 miles from a 2013 Chevrolet Silverado 1500 crew cab four door. VIN code 2 (L9H Flex Fuel). Head casting number is 823.
Motor should be shipping today so I am looking forward to picking it up and getting started.
This is also my first post.
1970C20L9H is offline   Reply With Quote
Old 03-18-2014, 05:30 PM   #2
BlacklandCamper
Re: 1970 c20 l9h 6l90e
Welcome to the board. Hope your swap goes smoothly.
Post pics, and don't be afraid to ask questions.
Grunt: 1971 C20 Custom Camper. Runs/Drives/Kinda stops. 350Ci, TH350. 4.10:1 D60. Eight Lug LWB is more better. Hell no its not fast!
Donkey: 93 Nissan D21, the farm truck. My 1/2 ton SWB. The Indomitable Datsun.
1st BN 3rd MAR. '00-'04
BlacklandCamper is offline   Reply With Quote
Old 03-18-2014, 08:01 PM   #3
1970C20L9H
Here is a picture of the motor/trans pullout I purchased.
Old 03-20-2014, 03:05 AM   #4
1970C20L9H
The engine has been crated and shipped
Old 03-20-2014, 03:07 AM   #5
1970C20L9H
Here is a picture of the truck
Old 09-07-2014, 02:15 AM   #6
1970C20L9H
Ok, people love pictures so I will add a few more up to my current progress....
Here is the old motor that I threw a rod on.
Pulling old motor
That looks bad...
lets take a closer look
m22 4 speed.
Now I have to use an air chisel to remove that transmission crossmember.
Transmission Crossmember removed, engine bay is pressure washed. Good enough for me.
Old 09-07-2014, 02:17 AM   #7
1970C20L9H
I have dropped the motor and transmission in to check for fitment and it looks real nice but the motor mounts don't quite fit.
Old 09-07-2014, 02:26 AM   #8
1970C20L9H
I currently have the $30 eBay motor mount adapters using stock motor mounts and the problem is that its placing the motor mounts about 1/2" to 3/4" wider than stock so bolt holes aren't lining up
so.. I am trying to figure out a new solution for motor mounts...
I see muscle rods has a nice kit but $$$$$ .... $280 or $479.00 including transmission crossmember and mount.
Performance Online has a nice looking kit for $129.99 thats looking to be the best option right now.
anyone else have ideas?
Old 09-08-2014, 12:06 AM   #9
1970C20L9H
anyone know how I can edit my first post here in this thread so I can keep most up to date info/status in the first post of the thread?
Old 09-08-2014, 11:24 AM   #10
mcbassin
Still Learning
mcbassin's Avatar
I used stock 73 up clamshell mounts on mine. I already had a pair of these with my truck. I'll see if I can dig up my pictures. I only spent a few bucks on the adapter plates. My engine fit great, but as you probably already know you will need a high hump tranny cover.
Edit: you can see pictures of my setup starting : HERE
You have to be a subscribing member to edit posts after a few minutes (I think).
What did you have to pay for you 6.2 6L80 combo if you don't mind saying.?
mcbassin is offline   Reply With Quote
Old 09-08-2014, 11:58 AM   #11
1970C20L9H
Thanks for your reply mcbassin.
I ordered the performance online mounts already because I want to get the show on the road. After further consideration I think I would have rather ordered the ECE mounts. I saw your comments about 73+ clamshell last night but I did not want to have to deal with trying to hunt those down, If at all possible I would like to have this thing rolling by November 1 but I think that is a tall order.
For the same price I could have bought a brand new LS3 430HP from Jegs but then I would still need a transmission, torque converter, flywheel, starter, alternator, power steering pump, AC compressor, all the brackets to hang them on the motor, wire harness and ECU.
This combo has 7000 miles on it so it should be as good as new.
Sometimes I wish I had just bought the LS3 from jegs because then I could use Holly EFI. with this combo (VVT and 6L80E) I am limited to stock ECU or Mast Motorsports M90 but they don't respond to emails so I am going with stock ECU
Old 09-09-2014, 01:17 PM   #12
Low Elco
If you can weld, bolt plates to the crossmember and adapt to the late motor mounts. Not too hard, and you can put it wherever you want and clear everything. You can see what I mean in the Yeller thread. There is an LSX swap section on the site with tons of good info. Great build!
Low Elco is offline   Reply With Quote
Old 09-09-2014, 03:02 PM   #13
1970C20L9H
I don't have a welder, when budget permits I plan to buy a millermatic 211
Old 09-13-2014, 01:12 AM   #14
1970C20L9H
Look what got delivered this evening...
Performance Online motor mounts and perch
Old 09-14-2014, 02:52 AM   #15
1970C20L9H
Upon closer inspection it appears the weld on one side of each perch is getting in the way of the motor mount...
With the motor mount as close as it gets.
Out comes the cutting wheel...
And now the motor mount fits on the perch.
Old 09-15-2014, 03:30 AM   #16
1970C20L9H
I got the motor mounts and transmission cross member installed today.
These performance online motor mounts were not lining up either but after a little wiggling I finally got it mounted up. Makes me wonder if I could have given a little more elbow grease and mounted it up with the stock mounts. I have no regrets.
Here are some photos.
Here is driver side mount from a couple different angles.
CPP Transmission Crossmember and transmission mount
And it is all mounted up....
Old 09-23-2014, 12:30 AM   #17
1970C20L9H
So, I attempted to install the stock manifolds that came with the engine (2012 Silverado). The driver side fit but is touching the frame so I would expect it to rub and the passenger side will not fit without notching the frame. I do not want to notch the frame. Doing a little research it seems the Camaro or Corvette manifolds should fit so I bought a pair on eBay. Still awaiting delivery.
I also ordered some electrical wire to finish up the wire harness with the help of documentation on lt1swap.com and their Facebook page.
Old 09-23-2014, 09:11 AM   #18
nlped
nlped's Avatar
This thing is going to be a runner... Sub'd
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 09-23-2014, 11:11 AM   #19
mcbassin
Still Learning
mcbassin's Avatar
Very nice progress on the powerplant install.
Old 09-23-2014, 07:05 PM   #20
1970C20L9H
Thanks, progress is slow but I am making progress. Unfortunately the cheapest I could find the all of the electrical wire in one place required the minimum purchase of 250' of wire for each selection...
12 AWG RED
16 AWG GRAY
16 AWG PINK
20 AWG ORANGE
20 AWG PINK
20 AWG BLACK
So I will likely have more than 240' of each left over.
Also, I ordered Automotive Cross Link TXL Wire which is the same high quality wire that Painless uses for their harnesses. It exceeds OEM specifications for underhood heat. This is better than the "primary" wire found at most parts stores.
Cross-link wire meets SAE J1128 standards and is designed for applications where higher heat resistance is required.
Old 09-24-2014, 08:19 AM   #21
mcbassin
Still Learning
mcbassin's Avatar
12 AWG RED
16 AWG GRAY
16 AWG PINK
20 AWG ORANGE
20 AWG PINK
20 AWG BLACK
Sounds like you are going to build your own harness from scratch? That would be much cleaner than reworking the stock harness. I would imagine all the connectors and wire will be quite expensive though.
Old 09-24-2014, 10:53 AM   #22
1970C20L9H
Not going to build my own harness from scratch but I couldn't find a decent price on shorter lengths of TXL wire. If I had bought 25' lengths it would have ended up being almost the same cost.
Old 09-25-2014, 10:41 PM   #23
1970C20L9H
Feeling defeated tonight. I received the LS3 exhaust manifolds today and they do not fit either. WTF
Old 09-26-2014, 02:53 AM   #24
boynton
boynton's Avatar
This is a complete rework that makes this swap much easier.
http://www.currentperformance.com/sh...-modification/
here is what I bought that helped me with my modified harness
http://www.currentperformance.com/sh...erelay-module/
hope this helps with the wiring decision.
As far as your exhaust manifolds, I used trailblazer SS manifolds and only had to trim a very minor piece from the right side of the frame. You should be able to see it on page 3/4 of my One Owner Short Step build thread.
Just trying to figure this out...
1970 SWB Step-Side
http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=584499
1970 SWB One Owner Step Side 6.0 LY6/6L90
http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide
http://67-72chevytrucks.com/vboard/s...86#post7531186
boynton is offline   Reply With Quote
Old 09-26-2014, 03:05 AM   #25
boynton
boynton's Avatar
Do you have any pictures of the LS3 manifolds in place? I really thought these would fit too.
1970 SWB Step-Side
6l90e, c20, l92, l9h, swap
