Old 03-20-2014, 04:01 PM   #1
lawest
'69 4X4 with 350 auto, PS, A/C questions
I am converting a '69 K10 from 6 cyl manual to 350 auto and adding PS and A/C. Does anyone have pictures or information that will help me determine where and how the PS pump and A/C compressor mount and how the crank and waterpump pulleys are configured. Would this set up take a long or short waterpump? Also, I was told that the Crank pulley set up is actually two 2 groove pulleys stacked together. If so I have no idea how the belts would be ran. I was also told that the '69 was only offered with A/C in certain models and that it is different than the '70 model. Any help would be appreciated.
69 K10 SWB Project Dream '69
2011 K2500 Silverado
Beat to fit, Paint to match
Dream '69 Build Thread
lawest is offline   Reply With Quote
Old 03-24-2014, 08:11 PM   #2
cableguy0
Re: '69 4X4 with 350 auto, PS, A/C questions
The easiest way for you to do what your wanting to do will be A)buy a complete serpentine belt setup from gm which runs about 750 but it comes with an ac compressor,new water pump,alternator and power steering pump or find the same setup used from a newer truck and pull everything from the same vehicle. Option B) is to find a stock setup from a 67-72 and get everything from the same truck. The issue is that gm used A LOT of different pulley and bracket configurations. If you don't get everything from the same vehicle there is a really good chance you will have alignment issues. Personally I like the serpentine setups because for 60k miles or so there is 0 maintenance.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
