Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Closed Thread
Old 04-04-2014, 10:09 PM   #1
Pro Performance
Pro Performance's Avatar
New: Porterbuilt Inner Frame Structure
This is Porterbuilt's new inner frame structure for the 63-72 C10, that is now in production. This inner frame structure will have the integrated trans mount and trailing arm crossmember, which are both adjustable. It will include all your hardware and frame mounting brackets to install into the truck.
This will work with most transmissions, including the 4L80E.
Priced @ $995
Porterbuilt Inner Frame Structure:
http://www.azproperformance.com/Port...63-72-C10.html
Pro Performance is offline
Old 04-05-2014, 11:39 AM   #2
greystoke
Re: New: Porterbuilt Inner Frame Structure
that is one awesome piece. I'm in wait mode for a large porterbuilt order for my 59 so this will be another day.
"Fear makes the wolf look bigger"
http://67-72chevytrucks.com/vboard/s...d.php?t=305629
greystoke is offline
Old 04-07-2014, 05:39 PM   #3
Pro Performance
They did an awesome job on this one (as they always do), and really is a nice addition to their line up.
Old 04-08-2014, 02:08 AM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
holy crap this is rad, but I'm curious....why? I get the trailing arm xmember, and I get the idea of the trans xmember...but is there a reason to put it all together in a box unit like this? Is it a structural rigidity thing (with the brackets boxing the frame out)?
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline
Old 04-08-2014, 05:03 AM   #5
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
Nope... don't need one... Nope... don't want one even a little bit...
CRAP!! I gotta have one!! Freakin' Nate and his new stuff!!
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline
Old 04-08-2014, 10:25 AM   #6
Pro Performance
It makes the frame more rigid, just as you mentioned, and also for aesthetic reasons.
I feel the same way!
Old 04-13-2014, 07:23 AM   #7
rob32472
price with shipping to 30157 please.
rob32472 is offline
Old 04-13-2014, 08:57 AM   #8
bbcmudtruck
So would this help with cornering and planting high hp and tq? Help me justify this piece of art beyond the reasoning of art! Also, would i still be able to use 3" exhaust with a bbc, th 400 and gear vendors overdrive?
bbcmudtruck is offline
Old 04-14-2014, 01:40 PM   #9
Pro Performance
This item has to go via truck freight, so it is higher than usual, since it can't go in multiple boxes being one piece. I am still awaiting final shipping cost from PB on this, once they ship one and have an idea of freight costs. I will post back in this thread once I know for sure.
This will stiffen the frame and make it more rigid. As for getting the horsepower to the ground better, I would think it would help some by offering less flex, but very minimal. I don't have any exact numbers to give you on this, unfortunately. But like you said, it is an art piece, and will look good in the frame.
It will clear 3", and will have the regular clearance of their tubular trailing arm crossmember. The 3" is a little tight, but can be done.
Old 04-14-2014, 02:19 PM   #10
bbcmudtruck
Cool. Any idea when they will be in stock?
Old 04-14-2014, 05:18 PM   #11
rob32472
I will be waiting....
rob32472 is offline
Old 04-14-2014, 08:20 PM   #12
slowcpe
slowcpe's Avatar
Not sure if I'm glad or not that I decided to wait on the trailing arm crossmember. That is going to cost me a whole lot more money as I now I have to have one.
Ryan
1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840
1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628
1967/71 Blue SWB C10..SOLD
1977 SWB K10..my grandpa's.....never should have sold
slowcpe is offline
Old 04-17-2014, 06:47 PM   #13
Pro Performance
This is on our list to stock, and should be on the next round of parts coming in. Right now, it is an appx. 8 week build time.
Good news guys.... it looks like it can go regular UPS and shipping will be $150 in the lower 48 states. Shipping has been updated on our site.
https://www.azproperformance.com/Por...63-72-C10.html
Old 04-19-2014, 05:30 PM   #14
biohazardbill
Im guessing to put that bad boy in you will have to completely separate both frame rails and reassemble?
biohazardbill is offline
Old 04-19-2014, 08:51 PM   #15
rob32472
This will boltin without seperating the frame rails... It has plates that bolt to the frame and then the structure bolts to them... This is designed for two peice drive shafts thou. I am running a one peice so that puts me out. Otherwise one would be headed my way already...
rob32472 is offline
Old 04-19-2014, 10:12 PM   #16
Rodzzilla
Can't wait.
Rodzzilla is offline
Old 04-20-2014, 01:05 PM   #17
Captainfab
60-66 Nut
Has Porterbuilt said that it won't work with a one piece driveshaft? I don't see why it won't work.
Captainfab is offline
Old 04-20-2014, 02:13 PM   #18
Pro Performance
Your thinking is correct, and I have sold 2 piece trailing arm crossmembers to guys that think they may switch in the future, due to drop members. You will be fine, unless you just don't want the carrier bearing mounting spot there. I am sure a 1-piece version is around the corner.
Old 04-20-2014, 02:46 PM   #19
rob32472
If you are sure this will work I will place the order... LMK for sure. Thanks
rob32472 is offline
Old 04-20-2014, 07:16 PM   #20
rob32472
Porterbuilt Fabrication:we don't yet make one set up for the one-piece driveshaft but it won't be hard for us to make the change and produce them as well.
April 17 at 5:25pm
This was posted on the porterbuilt facebook page. It does not say it wont work but doesn't say it will either
rob32472 is offline
Old 04-21-2014, 10:40 PM   #21
Pro Performance
I talked to Nate today, and it won't exactly work. The driveshaft will work clear through the trailing arm crossmember opening, but will more than likely not have enough clearance for movement.
You order, and it will come....
It is in the works shortly, so if one is ordered, it will get built. Should be in the normal build time, but because it will be a first one, may add just a little time. Not many adjustments are needed.
Old 04-22-2014, 12:08 PM   #22
Pro Performance
Wanted to mention, this is an introductory price of $995 for forum members, that will be good until the end of April. The price starting May 1st, will be $1,199.
The website will reflect the new price, but use coupon code "april" to get the $995 price. You are also welcome to call and order as well.
Old 04-29-2014, 12:24 AM   #23
Pro Performance
TTT, there is 2 days left to get this Inner Frame Structure at the introductory price of $995.
Old 10-06-2014, 08:23 AM   #24
Ulysses
I understand a ton of time has not passed but I would like to know if PB has built these for the stock drive shafts. I am very interested in the RB products.
Thank You
Ulysses
Ulysses is offline
Old 10-06-2014, 12:17 PM   #25
Pro Performance
Ulysses
Yes, this frame structure will work using a static drop to laying the frame on the ground.
- Travis
Closed Thread
