04-05-2014, 08:39 PM | #1 |
A/C Center Vent Plug Set (LMC item) - anyone use this? Help or hurt flow?
Pls see Item 15 on here: http://www.lmctruck.com/icatalog/cb/full.aspx?Page=65
It's an a/c center vent plug kit. Note that it only plugs part of the system - i.e. eliminates somewhat redundant hoses and routing. Looks like a good idea to me - anyone done this? Space is at a premium down there - having only a single hose running from the center vent diverter to the center vent seems to make more sense to me. Thoughts? Thx, jocko Last edited by jocko; 04-05-2014 at 10:26 PM. |
04-05-2014, 08:59 PM | #2 |
70+ ( Old Skool Club )
Re: A/C Center Vent Plug Set (LMC item) - anyone use this? Help or hurt flow?
Looks like a good idea to me.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
04-05-2014, 10:59 PM | #3 |
Old member
I made my own and it seems to blow out harder. It's been this way close to 20 years now I guess. I took a plastic cap and plugged it off then taped it.
04-06-2014, 08:28 AM | #4 |
I used a rubber sheet and hose clamped it over the left side connector. It increases the air flow toward the driver some but it makes putting the hoses in place easier.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
04-06-2014, 08:30 AM | #5 |
I bought those exact ones and used them. They work fine but you can make your own, they are almost like PVC end caps
04-06-2014, 08:32 AM | #6 |
I saw that in the catalog, too. So I went to the hardware store and found some plastic caps, and covered the extra holes. I had always wondered why the factory had put two hoses on one vent, and when I turned on the blower, I found out why. By feeding the vent from only one side or the other, the air is forced into the cab at an angle. The air flow goes only to the driver or passenger, depending on which side you blocked. I would have gone back in and put two hoses on it if it wasn't so much trouble.
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
04-07-2014, 01:58 PM | #7 | |
04-07-2014, 02:05 PM | #8 | |
1971 K5 CST Blazer 1965 Chevelle Malibu 283 (sadly sold) 1968 Camaro 327 1968 Honda mini-trail z50a #377 1966 uh 1-D Huey |
04-07-2014, 02:07 PM | #9 |
Moderator
I bought a rubber pipe cap from Home Depot and did the same thing. Much more air volume now. Doesn't matter to me where the air is diverted, the cab is so small it cools off quickly anyways.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
04-07-2014, 02:25 PM | #10 |
Yup, same here. Wish I would have blocked the passengers side so the AC was not blowing directly on me.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
04-08-2014, 09:50 AM | #11 |
I put the cap on the driver side inlet, with the hose connected to the passenger side inlet, most of the air blows on the driver. I don't think this would be too much of a problem if you live in an area that is really hot. I realized that I have no center seat belt, so not likely to have a middle passenger either.
Tags |
a/c, hose, vent |
