04-05-2014, 11:31 PM | #1 |
65 gmc/Chevy 4x4 power steering?
Have any of you folks done power steering with a crossover on the Dana 44 used in the 3/4 ton 60-66 trucks? Is there a knuckle top I can use on the passenger side so I could run a dragline down from my new power box to the passenger knuckle? Or do I have to keep the power setup like the stock system which steers from the driver side knuckle?
04-06-2014, 07:08 AM | #2 |
Re: 65 gmc/Chevy 4x4 power steering?
I was gonna do this when I had my 62. Since the boxes bolt on the same way, I don't see why it wouldn't work. Company I bought the plate from said it won't, but he didn't know why it wouldn't. the knuckle is easy, find em on ebay, or if swapping the whole axle, up to 75-76 1/2 or 3/4 ton will have it. Jeeps in the 80s had the flat top too....
04-06-2014, 11:04 AM | #3 |
I don't believe you will be able to find 60-68 knuckle parts that will allow a crossover to steer the passenger side and drag the drivers.
To my knowledge, all the passenger side stuff just has the small king pin caps. No provisions for steering arms in that era for the passenger side. At least for the Dana 44 stuff.
1960 GMC K1500 LB Fleet Side 1962 GMC K1000 LB Step Side 1988 Chevrolet C2500 |
04-06-2014, 11:50 AM | #4 | |
04-06-2014, 01:02 PM | #5 |
you can have one made $$$
1961 chevy K10 my build is------------61K10 build |
04-06-2014, 01:06 PM | #6 |
04-06-2014, 06:44 PM | #7 |
Looks like a NAPCO front axle right there.
04-06-2014, 07:58 PM | #8 |
Also stock push pull, not crossover....
This place used to do it, but they changed their page and don't list it anymore... http://www.blackbirdscustomtrucks.com/index.html |
04-06-2014, 07:58 PM | #9 |
04-06-2014, 10:07 PM | #10 |
61k10 where did you get the pic?
04-06-2014, 10:10 PM | #11 |
big six if you need 1 made I can have 1 made for you
04-06-2014, 10:57 PM | #12 |
04-07-2014, 09:31 AM | #13 | |
