Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > LSx Classifieds
Old 04-06-2014, 12:38 AM   #1
Captainfab
60-66 Nut
LSx Engine Mount Adapter Plates
A member asked me to make him another set of these, so I made an extra set to offer for sale. These come as shown in the picture for $56.00 shipped in the USA. If you would like this set, post here in this thread and either send me a PM here on the forum or an email to captainfab454@ hotmail dot com for payment details.
Old 04-09-2014, 12:55 PM   #2
KMC3420
KMC3420's Avatar
Re: LSx Engine Mount Adapter Plates
Do you have any pictures of these installed and what mounts will they work with?
Keagan
68 SWB C-10 original 350 A/C 503 Mean Green
KMC3420 is offline   Reply With Quote
Old 04-10-2014, 02:22 AM   #3
Captainfab
60-66 Nut
No I do not have any installed pics. Any Gen I small block engine mount will bolt up.
Old 04-11-2014, 12:41 AM   #4
ksbrktracer
TNT-MOTORSPORTS
ksbrktracer's Avatar
Hey Captain ... Any Idea where these put the engine in relation to oem sbc. forwards / backwards .... If so how much does it move..?
ksbrktracer is offline   Reply With Quote
Old 04-11-2014, 11:06 PM   #5
Captainfab
60-66 Nut
These should position the engine in the original Gen I location.
Old 04-12-2014, 10:06 AM   #6
Willie Makeit
Willie Makeit's Avatar
So, if I pulled a GEN1 SBC out of a truck, and bolted these on the LSx engine, the LSx will go back in the same spot the GEN1 was sitting allowing the bellhousing face to be in the same position as the old engine?
I'm asking because I removed a GEN1 that was mounted to a TH350. I want to keep the TH350's placement as is (to retain driveshaft and linkage) and mount the LSx to it.
Will your mounts work?
Willie Makeit is offline   Reply With Quote
Old 04-12-2014, 11:07 AM   #7
Captainfab
60-66 Nut
I have not installed a set of these, but that is what I understand from the dimensions I used to make these for other members. Someone that has installed a LSx with this style of adapter plate could give you a definite answer.
Old 04-12-2014, 09:44 PM   #8
PGSigns
PGSigns's Avatar
Most of these type of plates move the engine an 1 1/2 or more forward. This is to allow the head to clear the fire wall. The distance from the back of the head to the mounting surface for the bell housing is shorter on the LS engines. If the head was close before it will be in a bad place with the LS.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 04-21-2014, 11:49 PM   #9
Captainfab
60-66 Nut
Here is a post that shows how these adapter plates position the engine. The text tells the position of the engine mount brackets.
http://www.67-72chevytrucks.com/vboa...6&postcount=18
Old 04-22-2014, 07:00 AM   #10
PGSigns
PGSigns's Avatar
Going by the drawings I have these are 1 1/4 forward if using the same location for the mounts on the frame. That should be a good spot for our trucks. (60 to 66) to get off the fire wall.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 04-25-2014, 04:25 PM   #11
mcm1209
mcm1209's Avatar
I got s front crossmember out of an 85. Will these work with the new style engine mounts?
mcm1209 is offline   Reply With Quote
Old 04-25-2014, 11:51 PM   #12
Captainfab
60-66 Nut
Yes. As stated above, these will work with all Gen I small block engine mounts. They will also work with Gen II and Big block engine mounts since the bolt pattern is the same for all of them
Old 05-07-2014, 11:18 PM   #13
Captainfab
60-66 Nut
These have been sold.
Old 10-01-2014, 08:13 AM   #14
LS64C10
LS64C10's Avatar
Captainfab do you have anymore of these adapter plates laying around?
LS64C10 is offline   Reply With Quote
Old 10-01-2014, 11:35 PM   #15
Captainfab
60-66 Nut
No I do not. I can make more upon request though. I replied to your PM.
