Old 04-06-2014, 06:26 PM   #1
Green 1959
Green 1959's Avatar
1980 GMC truck
Starting the build for my new truck. Mostly going to be for hunting, I will get some pictures up soon.
I pity the fool with only 2 headlights!
Green 1959 is offline   Reply With Quote
Old 05-03-2014, 12:07 AM   #2
Green 1959
Green 1959's Avatar
Re: 1980 GMC truck
Here we are getting ready to be moved for the first time in 4 years! The DOT on on the spare tire shows it to be from '86! Might be time for some new ones, drove it from Worland to Casper and got 15.15 miles per gallon and 1/4 of the tank was some of that 4 year old fuel and a average speed of 70 MPH. So pretty excited about that, don't think that it will do too well in town though because the tires are way bigger than they should be. I need to also get the factory cruise control working and the left rear brake keeps locking up, my Dad was not much for maintence. He had grain in the bed for the 4 years it was parked so there is some surface rust. Also tring to decide on the audio system, I have a head unit but don't want to cut the dash considering putting it under the dash. I need to look up hubcaps, it has bow tie caps on it that I like...
Old 05-03-2014, 10:30 AM   #3
Zane M
Re: 1980 GMC truck
Looks like a good starting point.
Zane M is offline   Reply With Quote
Old 05-04-2014, 09:02 AM   #4
aotte1
Re: 1980 GMC truck
Sounds like things are going well on getting the truck back on the road. What year, etc is your truck?
Les
aotte1 is offline   Reply With Quote
Old 05-06-2014, 01:31 AM   #5
Green 1959
Green 1959's Avatar
Re: 1980 GMC truck
Les
It's a 1980 GMC Sierra Grande 1/2ton 4wd, it has the factory option 16 inch rims. I have just put new tires on it, only to find out that all 5 rims are bent. Previous owner beat it pretty hard LOL. Other than that it is a run of the mill 350 with a turbo 350 and a 208 transfer case. The engine I built for another truck when I was in high school, it was out a of truck that the engine was locked up on. Found water in one of the cylinders because the hood was left off with no air cleaner, I was able to disasseble without destroying the pistons and to the dismay of my auto shop teacher put new rings in it, rebuilt the heads and ran it. He said it would never last and it out lasted the truck I put it in for 7 years and then now in this truck for a couple years on my dad driving it (beating). I am in the planning stages of putting a air system in it so I can air put tires on the road and had minor use of air tools.
Old 05-06-2014, 01:32 AM   #6
Green 1959
Green 1959's Avatar
Re: 1980 GMC truck
I was looking at the registration for the truck and I did it May 1st. I found the receipt from when my Dad bought it in 1992 and was shocked to see that he bought in on May 1st of that year. Crazy..
Old 05-29-2014, 01:10 AM   #7
Green 1959
Green 1959's Avatar
Re: 1980 GMC truck
I am working on ideas to make the truck ride smoother... off road as well. I put tall profile tires on the should help, I need to replace the shocks. Checked cab mounts and they are still decent. Also having to replace 4 bent rims. I am debating and doing air over leaf, or just doing air shocks.. Any suggestions??
Old 07-06-2014, 10:56 PM   #8
Green 1959
Green 1959's Avatar
Re: 1980 GMC truck
Installed new ball joints on the 4th. Took only a couple hours with help from a friend from work!
Old 07-11-2014, 02:11 AM   #9
y5mgisi
Second Chance Program
y5mgisi's Avatar
Re: 1980 GMC truck
Subscribed.
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 09-01-2014, 10:34 PM   #10
Green 1959
Green 1959's Avatar
Re: 1980 GMC truck
Some important upgrades, gun rack. I'm ready for hunting season and... I guess WWII. And I've got to have Vader. Going to post some more impressive projects soon.
Old 09-03-2014, 07:50 PM   #11
Green 1959
Green 1959's Avatar
Re: 1980 GMC truck
I am doing a stereo install and am wondering what suggestions you guys have for putting 6x9 behind the seat. Looking for something that is not going to take a lot of space. I like to have a lot of crap behind my seat.
Old 09-03-2014, 08:42 PM   #12
y5mgisi
y5mgisi's Avatar
Re: 1980 GMC truck
http://www.73-87.com/Parts/7387Speak...20Brackets.htm
Old 09-05-2014, 12:35 AM   #13
Green 1959
Green 1959's Avatar
Re: 1980 GMC truck
I like!! Hopefully will get some pictures of what I'm doing so far tomorrow.
Old 09-05-2014, 11:46 PM   #14
Green 1959
Green 1959's Avatar
Re: 1980 GMC truck
Replaced the headlight bezel, looks a little better.
Old 09-05-2014, 11:47 PM   #15
Green 1959
Green 1959's Avatar
Re: 1980 GMC truck
Here is some of the stereo progress. The one picture is a speaker box LOL
Old 09-05-2014, 11:50 PM   #16
Green 1959
Green 1959's Avatar
Re: 1980 GMC truck
Meh
Old 09-05-2014, 11:51 PM   #17
Green 1959
Green 1959's Avatar
Re: 1980 GMC truck
Speaker box!!!!
Old 09-07-2014, 01:18 AM   #18
Green 1959
Green 1959's Avatar
Re: 1980 GMC truck
Does anyone know what lube is supposed to go in the transfer case?
Old 09-07-2014, 01:51 AM   #19
Green 1959
Green 1959's Avatar
Re: 1980 GMC truck
I think there might be leakage between the t case and trans, I am hoping that gear lube is the way to go though because I think that t case makes too much noise sometimes. I need to know soon because the season of the hunt is near and the fluid needs to be done, I don't think my dad ever changed it and he has had it since 91. On a different note what suggestions are there on a complete exhaust system? I'm looking to a easy to install and quite dual system.
Old 11-13-2020, 10:57 PM   #20
Green 1959
Green 1959's Avatar
Re: 1980 GMC truck
Hasn't been much done. It has Tundra rims now lol
Old 11-14-2020, 11:26 AM   #21
bhc41051
bhc41051's Avatar
Re: 1980 GMC truck
80W90 Gear Oil for the NP205
bhc41051 is offline   Reply With Quote
