Old 04-12-2014, 08:57 PM   #1
papsoldblue72
papsoldblue72's Avatar
Question Engine primer and paint
What kind is the best to use???? So that it doesn't peel off...
It's been a long time coming... It's time to get it done..
papsoldblue72 is offline   Reply With Quote
Old 04-13-2014, 12:09 AM   #2
'68OrangeSunshine
'68OrangeSunshine's Avatar
Re: Engine primer and paint
I've had good results with VHT.
Old 04-13-2014, 12:29 AM   #3
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Or Duplicolor. Paint isn't the problem... it's prep of the the surfaces to be painted.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 04-13-2014, 07:25 AM   #4
papsoldblue72
Question Re: Engine primer and paint
Gary
Ok is there something special I need to do to the surface of the block??? Does the primer I use need to be heat resistant ???
Old 04-13-2014, 07:40 AM   #5
I've never used primer and generally use Dupli-color. Alcohol or lacquer thinner prep well. I've used break Clean to degrease and painted straight after that. I'm sure there are more professional ways. But I'm not talking show quality,just simple and easy
Old 04-13-2014, 02:02 PM   #6
GASoline71
GASoline71's Avatar
Engines are greasy by nature. Even newly rebuilt ones. So I use either brake clean or contact cleaner on mine. Acetone works too.
Yes you will need an engine heat rated primer. They are right along side the engine paints in the parts stores. I don't use a primer either. I usually do about 4 to 5 coats f paint.
Gary
Old 04-13-2014, 04:28 PM   #7
'68OrangeSunshine
In Tucson, I take advantage of the Sun, and leave the part out in full sunshine to warm up, before shooting paint. I also shoot the surfaces down with Brake Cleaner, but let it evaporate completely [and the part to warm back up] before painting. I have tried it with hi temp primer and without and can't say one is better than the other. VHT is a division of Dupli-Color now, but that high heat range is better on headers and exhaust manifolds. Hi Temp [+500*F] Dupli-Color is OK.
If you're not shooting on bare metal, scuff the surface wth steel wool.
Old 04-13-2014, 07:21 PM   #8
Bigdav160
Bigdav160's Avatar
I shot several engines with epoxy primer then base coat/clear coat.
They still look pretty.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 04-15-2014, 12:58 PM   #9
papsoldblue72
Gary
Thanks Gary...... I think I'm going to go with the Dupli-color engine primer and paint...
Old 04-15-2014, 01:05 PM   #10
LUCKTRUCK
LUCKTRUCK's Avatar
I've had good results with PPG epoxy primer and VHT spray.
LUCKTRUCK
LUCKTRUCK is offline   Reply With Quote
Old 04-15-2014, 01:07 PM   #11
knomadd
knomadd's Avatar
If you're not looking for a glass smooth surface, primer isn't really needed. I've only used primer once on an intake manifold and it didn't make a difference what-so-ever. Save your time and money. And I use the Dupli-color engine enamel too. On a driveable vehicle, I'll take it to a local quarter car wash, spray it with engine degreaser, use a scraper for large particles then wash it off and let it dry. Before I paint it, I'll use brake cleaner for the residue and just paint it.
If you have peeling/chipping paint, you'll want to scrape that off or your new paint will still come off.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 04-15-2014, 04:57 PM   #12
bMr
Resprayed this engine last weekend after cleaning in Purple Power, brake cleaner, and a bristle brush. Local machine shop bead blasted the oil pan, valve covers and timing cover for a very reasonable price and it was totally worth it; I literally sprayed them down in brake cleaner to degrease the finger prints then shot the orange.
Dupli-Color low gloss black, VHT Chevy orange, and (uncured) VHT header paint on the manifolds. Previously all of the engine was in Dupli-color Chevy orange, which held up pretty darn well over the last 15 years.
bMr is offline   Reply With Quote
Old 04-16-2014, 10:22 PM   #13
brad_man_72
the boat guy
brad_man_72's Avatar
Prep prep prep.
Ground everything down till It was smooth, clean, then spray bombed it. I've seen worse in $100k street rods.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 04-16-2014, 10:29 PM   #14
litew8
litew8's Avatar
"Dawn - Takes grease out of your way!"
project: "my happy mess"
litew8 is offline   Reply With Quote
Old 04-16-2014, 10:36 PM   #15
roxxx
Wurth has a product at is specifically for cleaning surfaces for auto body you can buy it om large cost effective containers and put it in a regular spray bottle
Next time I am at my client i will find out what it is
roxxx is offline   Reply With Quote
engine, paint, primer, problems
