Old 04-23-2014, 06:36 PM   #1
SoCalSlaughter
SoCalSlaughter's Avatar
Engine vaccum - 90' Suburban
Does anyone know what the engine vacuum should be pulling at idle, at sea level? Im trying to solve a puff from my exhaust, and checking the vacuum for a possible intake leak, but cant find anything on the web for what the factory vaccum reading should be. At the moment the engine is pulling 18psi at operating temp in park. Thanks!
SoCalSlaughter is offline   Reply With Quote
Old 04-23-2014, 07:29 PM   #2
cableguy0
Re: Engine vaccum - 90' Suburban
18psi is in the right neighborhood especially considering its likely the engine is at least worn some. When does the puff happen and what color is it? Most of the time a puff from exhaust in a sbc is valve seals.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 04-23-2014, 07:29 PM   #3
Bigdav160
Bigdav160's Avatar
18" hg is perfectly acceptable. Is it steady? What is your ignition timing set at?
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 04-28-2014, 12:36 PM   #4
SoCalSlaughter
Thanks for the replies. The timing is set 4 degree's advanced. The vacuum is steady, doesn't pulse or jump around. And the muff is more noticeable at idle. I do think some of the valve steam seals are going, because on cold starts, it has a blue puff of smoke out the tail pipe, but doesnt smoke while driving. or consume oil.
intake leak, misfire, psi, vacuum
