Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 04-27-2014, 12:18 AM   #1
6066gmcguy
6066gmcguy's Avatar
Jolly's Rescue Squad Summer of 2014
To start off the summer I did a few repairs to the Rescue, had to replace the Master Cylinder, and repair & replaced some lights. I replaced the lights on the front of the Cabin with some School Bus lights.
I added to new red rotating lights to the rear.
The spot lights that use to be there kelp viberating loose.
Jolly ~ The 6066 GMC Guy
Try the 6066 GMC Guy Facebook Page
Jolly's Truck & Car Show Page!
6066gmcguy is offline   Reply With Quote
Old 04-27-2014, 12:55 AM   #2
6066gmcguy
6066gmcguy's Avatar
Re: Jolly's Rescue Squad Summer of 2014
I have been looking for some tires to install on 22.5" wheels, to replace the 20" lock ring wheels, I have a set of 7 tubeless 22.5" wheels, That came with the 1960 LCF I bought a while back, I'll be installing when I get time.
Three of the wheels are not on the chassis, and two of those are bad. So I started doing some tire research.
Old tires removed.
Tire on the Rescue Squad.
From what I have seen the shortest tire you can get is 255/70R22.5 which is about the same hight as the 20"s on there now. These can be pricy tires. I found one for $100, for my research, and then resold it for $100.
Next I found 2 motorhome tires for $200, they are a Michelin 235/80R22.5 this is a Michelin only tire size from what I have found out, and these tires go for over $500 each new.
I installed the new Used tires, as they have 17/32 tread, they are as close to new as you can get and still be used.
I just need to get time to install them on the Rescue Squad.
Old 04-27-2014, 12:59 AM   #3
6066gmcguy
6066gmcguy's Avatar
Last weekend, April 26th, I took the Rescue Squad to its first show of the summer, the Jelsco Awards Car Show.
the Rescue Squad won another Award!!!
Enjoy.
firetruck, gmc, show, truck
