Old 04-27-2014, 05:25 PM   #1
daveo68
daveo68's Avatar
700r4 lockup
I have TCI lockup wiring on my truck with the vacuum switch that uses brake switch. It is teed into the same line as vacuum advance for HEI dizzy. Should this be on separate vacuum source?
68 C-10 Custom LWB
307 V8
Lexington,NC
davideowens@lexcominc.net
God Bless America
daveo68 is offline   Reply With Quote
Old 04-27-2014, 07:08 PM   #2
hugger6933
Re: 700r4 lockup
Yes, it really should have its own vacuum source and of the manifold type if I remember. Jim
hugger6933 is offline   Reply With Quote
Old 04-27-2014, 10:55 PM   #3
daveo68
daveo68's Avatar
Re: 700r4 lockup
ttt
68 C-10 Custom LWB
307 V8
Lexington,NC
God Bless America
Old 04-27-2014, 11:13 PM   #4
SS Tim
SS Tim's Avatar
Re: 700r4 lockup
Since I was curious I did some looking and found this thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=476777
TCI's page
http://www.tciauto.com/tc/2004r-700r...iring-kithtml/
"Connect the vacuum switch to a
ported vacuum source on the carburetor or throttle body. (If you find
that the TCC operation is erratic in your application, then you may try
moving the vacuum source to the manifold.)"
Instructions, good reading.
SS Tim is offline   Reply With Quote
Old 04-28-2014, 03:11 AM   #5
daveo68
daveo68's Avatar
Re: 700r4 lockup
Thanks for the info, guys. I'm at work and just got a chance to get on the board. I didn't know if it would affect anything by being hooked up like that, it is running and shifting good. The shop that rebuilt my tranny hooked it up like this. I figured they know more about it than I do.
68 C-10 Custom LWB
307 V8
Lexington,NC
God Bless America
Old 04-28-2014, 07:18 AM   #6
jjzepplin
jjzepplin's Avatar
Re: 700r4 lockup
I hooked mine to a separate source. You have to adjust the switch a little.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 04-28-2014, 07:30 AM   #7
67 chevelle
67 chevelle's Avatar
Re: 700r4 lockup
alot of times the vacuum port for the distributor is timed , meaning it does not pull from idle to a certain point
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
