Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 05-03-2014, 03:11 PM   #1
5150
C10 Club Tennessee
5150's Avatar
Sony Digital Link System for Ipod
Ok, here's my issue. I'm attempting to run this setup:
http://www.crutchfield.com/S-olO1MV4...nd-System.html
I'm not using a radio deck at all, but I am trying to run an amp. My problem is that I can't get the amp to power up. I got power going into the amp and it's got a good ground. I have the blue remote wire from the Sony unit going to the remote on the amp. The Sony unit powers up and is charging my Ipod. What am I missing?
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 05-04-2014, 09:40 PM   #2
panhandler62
Java Mechanic
panhandler62's Avatar
Re: Sony Digital Link System for Ipod
Check the remote line, see what voltage you have to ground from it with the iPod unit powered up.
Keith
11 Lincoln MKT -- Momma's wagon
13 G37xS -- middle age crazy car
68 C20 Fleetside -- RIP
Decorating the whole town up at a cost of $27 ....
panhandler62 is offline   Reply With Quote
Old 05-05-2014, 02:54 PM   #3
_Ogre
_Ogre's Avatar
you can also use a 12v+ to trigger your amp to confirm it's operation
then back to what panhandler suggested, see if the sony box is outputting 12v+ to trigger the amp
a lot of truck people here are asking about ipod or mp3 players without a head unit
so when you get everything figured out, post up a build and review in this forum
just to be clear... no speaker hookup to the sony unit
rca cables to the amp and all speaker/sub hookups to the amp
is how you hook that up
crutchfield.com/Manual/158XDPM110
shop air compressor timer
Old 06-02-2014, 03:47 PM   #4
Hx16457
Hx16457's Avatar
The light on the unit is red correct? If the unit is on (12V applied), a blue light will be on, but when in use and trying to play from your IPOD/IPHONE, the light should be Red.
Just something simple to check.
People who make excuses didn't want to do it in the first place!
http://s1326.photobucket.com/albums/...cpZZ1QQtppZZ16
Hx16457 is offline   Reply With Quote
Old 06-02-2014, 06:09 PM   #5
5150
C10 Club Tennessee
5150's Avatar
I figured it out last week. Apparently the ipod had to be plugged into the unit before it would give power to the remote wire. All is good and it sounds fantastic.
Bryan
www.gmtruckshow.com
Old 06-03-2014, 12:55 PM   #6
_Ogre
_Ogre's Avatar
post up some build pics. a lot of people here would like to see it
Old 06-03-2014, 08:22 PM   #7
5150
C10 Club Tennessee
5150's Avatar
Well, I've already got it under my seat so pics won't be any good. I didn't wire any speakers up to it directly. I actually cut the speaker wires off. I only used the red, yellow, black, and blue wire. I'm running a 600 watt Boss amp off of it with two pairs of RCA jacks that plug into the system. I've got a pair of 6 inch speakers in the kick panels and a pair of 6x9's in the rear panels of my burb.
You plug your Ipod/Iphone into this cradle and then a separate wire plugs into the bottom of the cradle. The only thing I don't like about it is that you can't plug the wire directly from the system to your Ipod/Iphone. You can't avoid having to use the cradle, or at least I haven't found a way too.
Bryan
www.gmtruckshow.com
Old 06-17-2014, 01:59 AM   #8
maxxxy
maxxxy's Avatar
Besides being able to have the cradle for hands free and charging, you could always run a $5 3.5mm-to-rca cable directly from your iPod's headphone jack to the amp's rca inputs.
Max
Max's bagged 81
81 rcsb bagged, 22s, build in progress
09 ext cab, 24" U2's, DD sub/amp
maxxxy is offline   Reply With Quote
