![]() Join Date: Nov 2013
Reverse Lights!
so my truck does not have reverse lights. and i see most 60-66 trucks do, which ones are the right ones to buy i cant seem to find them in catalog books or online. i want to paint my truck soon and it would be a good idea to get the reverse lights installed before then.
Re: Reverse Lights!
Were standard option in 66 I believe and optioned prior to that.
Do you have a fleetside or a stepside?
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
Re: Reverse Lights!
1963 Chevy c10 shortbed fleetside
Re: Reverse Lights!
Classic parts has them....heres the link : http://www.classicparts.com/1960-66-.../#.U3ZJ-RNOWUk
Re: Reverse Lights!
thanks, all i would need to do is cut out the whole correct? then these would go right in. no need to purchase anything else?
Re: Reverse Lights!
Correct. Your harness may or may not have the provision to hook up the lights. If not, an aftermarket harness for the bed will have it. I ordered my rear harness from classic parts a few years ago and it had the provision even though I do not use it. I can post some install instructions for you.
Re: Reverse Lights!
that would be great thankyou!
Re: Reverse Lights!
I'll post stepside, fleetside and suburban instructions. Column and manual shift in case it helps anyone else.
Re: Reverse Lights!
hardest thing you will have to deal with is the switch to turn them on unless your trans cover has been replaced with a later one that has the switch in it .... if you look above at page 318 you can see what they used in 63 with the 4 speed
Re: Reverse Lights!
Great instructions but without the locating templates, what do you do?
1953 3100 261cu in, sm420, 3.55 torque tube, omaha orange 1964 GMC 1000 series,custom, 305E, sm420 |
![]() Join Date: Oct 2017
Re: Reverse Lights!
Mine are actually a dealer installed(I think) mounted on brackets above the brake light and not in the fender. I know these are available online. I bought the classic parts rear lights wiring harness. Worked great. My backup lights are switched via toggle on dash right now though via my shadetree mechanic uncle.
Re: Reverse Lights!
My 66 Stepside with the SM-420 also had this type of (unobtanium) switch. I have the brackets and the old inoperable switch, I'm hoping I can rig up a brake light switch that will work.
#13 |
Re: Reverse Lights!
I’m looking to install taillights on my fleet side too. I have everything gathered, just need to find a template, or another fleet side with the factory holes already there so I can do some measuring. I want to make sure I’m 100% on this before I start cutting.
#14 |
Re: Reverse Lights!
Could you make available your measurements?
#15 |
![]() Join Date: Aug 2010
Re: Reverse Lights!
The search feature here is your friend.
