Old 05-26-2014, 01:49 PM   #1
jamesjones
Freakin Awesome!
jamesjones's Avatar
Stock fuel lines
I have a 72 Blazer that has stock hard lines going from the engine to just before the stock tank. I believe it's 3/8" line. Couldn't I just reuse the stock line and then use braided line from the stock hard line to the regulator/tank and engine?
This is for a returnless LQ4 swap.
1972 K5 Blazer - LQ4/TH350/NP205 - Long Travel Suspension - Hooptee
jamesjones is offline   Reply With Quote
Old 05-26-2014, 02:34 PM   #2
67Steven
67Steven's Avatar
Re: Stock fuel lines
I ran new 3/8" aluminum hardline for the 6.2, but my setup required it to be on the drivers side.
I ran flex from tank to frame and frame to fuel rail. So far, so good, I don't think I have starvation issues.
1972 Blazer build: http://67-72chevytrucks.com/vboard/s...d.php?t=615744
67Steven is offline   Reply With Quote
Old 05-26-2014, 02:34 PM   #3
DaveTurner
DaveTurner's Avatar
Yea, I used all braided -6 lines but I've seen guys use the stock line to high pressure rubber lines with fuel injection hose clamps
http://www.amazon.com/AAS-Fuel-Injection-Clamps-FI... http://www.amazon.com/AAS-Fuel-Injection-Clamps-FI...
DaveTurner is offline   Reply With Quote
Old 05-26-2014, 03:40 PM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Many Aluminum hard lines are only rated to about 25psi, so be careful. They can crush under compression fittings, or risk a burst failure, especially if its the kind that has a seam in it. Don't want any engine fires.
The P.o of my truck used it for the carb'd 355 since it was easy to bend by hand, but had to be replaced when I went lsx.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 05-28-2014, 02:12 PM   #5
jamesjones
Freakin Awesome!
jamesjones's Avatar
So the 72 hard line can be reused?
Old 05-28-2014, 03:58 PM   #6
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
If its the o.e. steel line, then yes, it should be a 3/8" feed, which is just fine for your fuel system...and it adapts nicely to -6 for hoses etc.
Old 05-29-2014, 05:46 AM   #7
jamesjones
Freakin Awesome!
jamesjones's Avatar
Sweet, thanks.
Old 11-10-2014, 11:15 AM   #8
papsoldblue72
papsoldblue72's Avatar
ok mine has two fuel lines which line do I use for suction because my fuel pump only has one inlet and one outlet????
It's been a long time coming... It's time to get it done..
papsoldblue72 is offline   Reply With Quote
