05-31-2014, 07:56 PM | #1 |
coolant temp sensor
I have the ls engine coolant sensor hooked to the ecm, but what about the one for my gauge how can i get a sensor on my engine for it?
70 C10 working on a LSx swap 4.8L MS3 edelbrock pro flo intake, pacesetter long tubes, 4l60e 2500 stall hoping the tranny holds up lol |
05-31-2014, 08:13 PM | #2 |
Old member
Re: coolant temp sensor
I used the spacer in the back of the passenger side head for my gauge.
05-31-2014, 11:13 PM | #3 |
Where did you put the one for your fans then?
I have my fans on the back of the passenger head, the ECM on the front of the drivers head, and then my guage we were going to weld a bung into the water pump but we haven't done anything yet. For right now I'm just using a bluetooth OBD2 scanner with my phone to keep an eye on it.
1972 C10 LWB Highlander Dark Olive/White - Work in progress 5.3/6L80e, Accuair e-level, Porterbuilt Stage 1 front and Stage 2 rear, Wilwood 14"F 13"R, Vintage Wheel Works V40 18x8/18x11, and more... Build Thread |
05-31-2014, 11:58 PM | #4 |
What gauge are you running? That will be a factor in what sender you use.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
06-01-2014, 07:08 AM | #5 |
Old member
The fans are controlled by the ECU which feeds off the sendor in the drivers side head.
06-01-2014, 03:05 PM | #6 |
06-01-2014, 06:24 PM | #7 |
i am using the factory gauge
06-02-2014, 10:11 AM | #8 |
Call me a chicken, but i didn't have enough balls to drill and tap the head to a 1/2" NPT. So i drilled and tapped the water pump.
1972 GMC Jimmy 4x4 LS Swap 1985 Chevy K20 1994 GMC Yukon 2021 GMC 2500HD Duramax AT4 My "It's a Jimmy Thing" Build http://67-72chevytrucks.com/vboard/s...d.php?t=583528 Budget Build 1985 K20 http://67-72chevytrucks.com/vboard/s...d.php?t=801565 |
06-02-2014, 02:04 PM | #9 |
I just started a thread on how I solved my problem.
Easy Coolant Temp Sensor Fix Hope tis helps |
06-02-2014, 06:56 PM | #10 |
Autometer makes everything you need, if you search my username there's a thread I posted in that contains all of the part #'s you need to use their adapter and sender with the stock 67-72 gauges.
I have one in my truck and the gauge is nice and linear in it's action and about vertical at 210* which is exactly where it should be with these motors. |
06-03-2014, 03:09 PM | #11 |
Enjoying left field
The PO stripped the hole in the front of the drivers head, so I drilled and tapped it to 1/2" NPT and put the stock 5.3 sensor in the rear of the passenger side. It was pretty easy. I put grease on the bit and tap to keep the bits of aluminum out of the head.
06-03-2014, 05:25 PM | #12 |
I did the same as Andy. Drivers side is for PCM which controls fans, pass side is for gauge. I actually get a different reading between the two. It's been as much as 20 degrees at some times.
Will 1968 C10 - Project Texa Go 6.0/4L80e 2003 Mitsubishi Lancer Evolution 2002 Ford Excursion 7.3L 2024 Toyota Sienna |
06-03-2014, 09:37 PM | #13 |
I drilled and tapped the top of the water pump.
68' c10 stepper 5.3/4L60e Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=578917 |
06-03-2014, 11:35 PM | #14 |
I drilled and tapped the water pump for the steam vent lines.
06-04-2014, 06:32 AM | #15 |
Old member
I also have the scan gauge 2 in the truck so I have 3 readings and yes the passenger side is always higher than the computer readings about 18 degree most of the time.
06-04-2014, 11:16 AM | #16 |
Enjoying left field
Is that gonna mess me up having the ecu sensor in the back hole?
06-04-2014, 10:51 PM | #17 | |
Guage adapter after removing the passenger side rear cylinder head OEM fitting is: (m12x1.5 - 1/8" NPT) Autometer 2277
1966 C10 SWB Fleet 5.3L LM7 Vortec / 4L60e Swap 1966 C10 w/ 5.3L/4L60e Build Thread 2012 GMC Sierra 5.3L 4x4 CCSB |
06-05-2014, 01:41 PM | #18 |
Yup that's^ the same thing I did. And good to know I'm not the only one with temp variation between the two. I'm not worried since my e-fans run off the pcm anyway so when I check my gauge I just look at it and subtract about 15 degrees in my head. I haven't had any overheating problems since the new rad anyway though.
06-05-2014, 09:13 PM | #19 |
Took the stock temp sensor from my 91 350 had it milled down to fit the passenger head, plugged right in, voila.
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854 1988 IROC-Z Camaro - 305/T5 T-Top 1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850 1991 V2500 Suburban Silverado - Sold 1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423 2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold 2003 1500 Silverado 2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold 2005 Silverado 2500HD 6.6/ZF6 CC LWB |
06-06-2014, 08:16 PM | #20 |
Good info!
What 1/8 npt auto meter / vdo sender works with our 67-72 gauges though. With the Autometer. 2277? Thanks! Should help the OP as well.
'71 C-10 with 5.3 LS2 cam & NWC T5 - Patina King! '83 Jeep Cherokee w 5.3 LS9 cam & SM465 NP208 swap in progress '92 Volvo 960 wagon w 5.3 LS7 cam & WC T5 swap in progress '79 Porsche 911 SC '48 Spartan Mansion 30' travel trailer '10 Porsche Cayenne S - Daily |
06-07-2014, 09:12 AM | #21 |
Does any of the late model cars/trucks use an idiot light. I am installing a lc9 in my 70 swb and just want to get a switch to make idiot light work. The right head is plugged on the back with a m12x1.5 bolt and washer.
Thanks |
06-11-2014, 10:46 PM | #22 |
I'll answer my own question here:
Autometer 2277 adapter. Auto Meter 2259 Short Sweep Electric Cyl. Head Temp Sensor (340°)
06-12-2014, 10:55 AM | #23 |
Wouldn't the adapter keep the sensor/switch from going into the coolant?
08-19-2016, 11:31 AM | #24 |
