Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork > Detailing
Old 06-01-2014, 05:01 PM   #1
lalink72
cleaning engine compartment
I'm looking for some advice/tips on how to cleanup the front/bottom of my motor and front suspension area on my '85 chevy c20. The motor,apparantlly, had an oil leak etc. for many years before i got it. After removing the fan,fan shroud, alternator, a/c compressor, power steering pump I got a real good idea how bad it is. At 1st I thought someone had tried to put and under-coating on the truck. It is really caked up on the front frame and suspension parts. Anyway, any help in this would be greatly appreciated.
lalink72 is offline   Reply With Quote
Old 06-02-2014, 07:59 PM   #2
thefraze_1020
thefraze_1020's Avatar
Re: cleaning engine compartment
Once, at my job, I had to clean the engine bay of an old forklift that had shot main seals, which leaked oil for 20 years.
I found what worked really well is to first scrape the thick stuff, then spray a d-Limonene degreaser (such as Orange Away).
It softened the grease right up.
Cameron
1984 Chevy C20 Custom Deluxe
thefraze_1020 is offline   Reply With Quote
Old 06-02-2014, 10:13 PM   #3
TBONE1964
Cluster King
TBONE1964's Avatar
Put your rain coat on and get a pressure washer to blow off the heavy stuff. Then use "Easy Off" oven cleaner and let it sit for about 30 minutes then pressure wash again. It will do wonders. Protect your skin and any painted areas you want to stay painted. Easy Off works better than paint stripper and it is excellent in cutting grease.
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com
I am also a dealer for Counterpart for gauge cluster parts only.
Also see my facebook page, CG&C
TBONE1964 is offline   Reply With Quote
Old 06-03-2014, 01:22 PM   #4
1963c-10
1963c-10's Avatar
Especially if you get the one with sodium hydroxide.....good stuff.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 06-03-2014, 06:55 PM   #5
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I use engine bright, right after coming home from a track day. Let that stuff bake in there while I take a shower, then come out with a beer n hose it all back off with the pressure washer set to "mist". High pressure water is your enemy, but lower pressure water wont hurt anything under hood.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 06-04-2014, 12:10 PM   #6
pwdcougar
pwdcougar's Avatar
I've always used Gunk. $4 or $5 a can at Walmart. Hit the heavy stuff with a scraper first though. 40 years worth of hardened grease came right off the trans and transfer case of my burb using Gunk and a small electric pressure washer. The raincoat is a great idea. Wish I had thought of that!
Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those"
1969 Mercury Cougar Standard 4 speed
1969 Mercury Cougar XR7 convertible
1970 4WD Chevrolet Suburban
1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997)
pwdcougar is offline   Reply With Quote
