Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork > Detailing
Old 06-06-2014, 04:43 PM   #1
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
What do you use?
I have some tar on my truck and I'm looking for a product that I can spray on the tar spots and then rub a bit and wipe the tar off. What do you guys/gals use to accomplish this?
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 06-06-2014, 04:51 PM   #2
Dunenutt
Newbee
Dunenutt's Avatar
Re: What do you use?
I use mineral spirits on a rag, then wax the area after.
Dunenutt is offline   Reply With Quote
Old 06-06-2014, 04:54 PM   #3
Tinkermc
Easy Off Cold Formula takes it right off and does no harm to the finish.
Tinkermc is offline   Reply With Quote
Old 06-06-2014, 04:57 PM   #4
FirstOwner69
FirstOwner69's Avatar
I agree with the mineral spirits suggestion. You can try WD-40 also. Diesel fuel or kerosene would probably be safe. Don't try lacquer thinner or acetone though!
FirstOwner69 is offline   Reply With Quote
Old 06-06-2014, 05:02 PM   #5
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
ESSO, EXXON, ENCO (yeah, that company) had a product called Varsol. I have used it with very good results. I don't know if you can find a station that has it....probably not going to be C-Store site.
Member Nr. 2770
Old 06-07-2014, 01:50 PM   #6
Dupont always made "Tar & Bug Remover" and that's what I've always used. I don't know if that's still out,but I still have some. I've used lacquer thinner for tar and many other stubborn things on paint with no ill affects,as well.
Old 06-07-2014, 02:05 PM   #7
In The Ten Ring
ZEP Inc (I think Home Depot carries their products) has both MVP and Orange Gel Degreaser.
The former is a hand cleaner that removes tar and the latter is a spray on that will. (I am pretty sure it will anyway).
Both are safe on the hands.
In The Ten Ring is offline   Reply With Quote
Old 06-07-2014, 06:53 PM   #8
Already Gone
Thanks for the tips, one of these ideas should work for me.
Old 06-07-2014, 10:26 PM   #9
Sicklajoie
The Niner
Sicklajoie's Avatar
I've always been happy with this stuff.
http://www.moreshine.com/Products/tarminator
"A good racer is one whose head is in communication with his balls." - Richie Evans
1970 C/20 - 402/TH400/3.54s - 74K miles
2003 GMC Sierra 2500 - Wheatland Yellow
Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183
Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/
Sicklajoie is offline   Reply With Quote
Old 06-08-2014, 03:54 PM   #10
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
GooBeGone (or any orange-oil or pine-oil extract) works really well. For satin finishes, there is a spot detailer from Chemical Guys that gets it off with minimal rubbing and n waxes
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 06-08-2014, 05:12 PM   #11
69chevytrucker
69chevytrucker's Avatar
slap shot by walter products
69chevytrucker is offline   Reply With Quote
Old 10-20-2014, 02:39 PM   #12
droberson
I know this thread is old and WD-40 was mentioned, but I do know that it works great to remove roofing tar from my hands and tools. It melts it right off.
droberson is offline   Reply With Quote
Old 11-11-2014, 06:31 PM   #13
doo142
doo142's Avatar
Amen brotha!! It works on road tar also
doo142 is offline   Reply With Quote
Old 11-13-2014, 01:57 PM   #14
nascarguy320
nascarguy320's Avatar
WD 40 is a great tar remover.
nascarguy320 is offline   Reply With Quote
Old 02-12-2015, 11:01 AM   #15
Shifty One
Shifty One's Avatar
Seafoam. I bought a Corvette from a former road racer, and it was pretty nasty behind the wheels, and nothing conventional (that wouldn't hurt the paint) was working. The Seafoam rep just happened to walk into work the next day, and he suggested it. I threatened to remove his toenails with a dead-blow hammer if it hurt the paint, but it worked like a charm!
