Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 06-08-2014, 10:19 PM   #1
ogsRULE
ogsRULE's Avatar
Gas Tank 60 Burb Chassis
Looks like I will not be able to use the original tank in my project (2WD, 60 chassis and 64 body). Looking on the forums it seems most of the easy blazer swaps are good for 63+ Does anyone have any experience swapping tanks in a 60-62 chassis?
Thanks,
Scottie
ogsRULE is offline   Reply With Quote
Old 06-09-2014, 12:52 AM   #2
MikeS.
MikeS.'s Avatar
Re: Gas Tank 60 Burb Chassis
Since the tank sits inside the frame, isn't the frame the same 60-66?
Past Master
Triluminar Lodge #117 GL of WVa
My 1963 4x4 Suburban build;
http://67-72chevytrucks.com/vboard/s...d.php?t=531274
My Gallery, now with pics of my 1966 C30 motorhome.
http://67-72chevytrucks.com/gallery/...&ppuser=103447
MikeS. is offline   Reply With Quote
Old 06-09-2014, 01:04 AM   #3
ogsRULE
ogsRULE's Avatar
I'm learning as I'm going here but seems the frames are different 60-62 vs 63-66. My frame is an "X" construction and seems dims on the back rails are some how different?? I think narrower.
Scottie
Old 06-11-2014, 01:11 AM   #4
Captainfab
60-66 Nut
That is correct. The 2wd '60-'62 frames are wider at the rear than the '63-'72 frames. The 4wd '60-'62 frames are the same as the '63-'72's
I know that Boyds Welding makes tanks for the '60-'62 trucks, but those may be out of your budget? His for sale thread can be found in the 'Vendors Marketplace' here on the forum.The next one I would look at is the universal gas tank by Tanks Inc.
Old 06-11-2014, 10:31 PM   #5
ogsRULE
ogsRULE's Avatar
Thanks for the ideas. Boyds is sweet but whoa$$.
GMCPauls is showing the 69-72 Blazer kit to fit with a bracket or easy mod. Looks like that would be a good go.
Thanks,
Scottie
Old 06-12-2014, 04:57 AM   #6
monolith
Zero Albedo
monolith's Avatar
For extended range you can also try Aero Tanks in San Bernardino California.
I have one-you can see the details in my 1 ton Panel thread.
Baz
"Deserve's got nothin' to do with it."
66 GMC 1500 wideside longbed 250 4spd "Project Rekker"http://67-72chevytrucks.com/vboard/s...d.php?t=467467
65 GMC 1Ton Panelhttp://67-72chevytrucks.com/vboard/s...32#post4794432
65 Chevy Panel (former U.S.Navy truck)
64 Chevy Suburban Carryall 4x4http://67-72chevytrucks.com/vboard/s...d.php?t=358348
64 GMC 1000 wideside longbed 305 4spdhttp://67-72chevytrucks.com/vboard/s....php?p=3600890(Rip- parts truck now)
68 Dodge Charger
monolith is offline   Reply With Quote
gas tank, suburban
