Old 06-22-2014, 12:12 PM   #1
Td87
2nd Gen in 87
Hey everyone. I've got a 2nd gen 6bt mounted in my 87 1 ton. I'm using the dodge automatic and still gotta find an np205 29 spline. I bought a full donor truck so I wanted to use the dodge pcm, but I can't find any info online with wiring the pcm into my 87. As far as everything else related to the swap I've got it pretty much licked, it's just the wiring side of it that's holding me back. If anyone has ever done this or has any input on how I could go about wiring this, I'd appreciate it very much. Thank you
Td87 is offline   Reply With Quote
Old 06-22-2014, 08:21 PM   #2
ryanroo
ryanroo's Avatar
Re: 2nd Gen in 87
To my knowledge there are no dodge autos that used the 29 spline output definitely not in that era. you will need a 23 spline input. they are a different case than the 29 spline and the two inputs don't cross. 23 splines came in any dodge auto through the 205 years.
for the wiring, i dont thing you need the PCM to communicate with anything other than the inputs from the engine and transmission. from there it will make the call for shifting/lockup and acts as the OEM dodge alternators voltage regulator as well as the timer for the toasters. i dont think you need to do anything to integrate it with the GM harness other than give it a good power source and ground it appropriately. the gm dash can be made to work with the correct senders and the stock gauge harness modified for the new engine.
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 06-23-2014, 01:22 AM   #3
Td87
Re: 2nd Gen in 87
Ok for some reason I thought I needed to find a 205 case from a 1st gen because it has the right side drop. Cuz I have a 241 case but that's got the left side drop. Is the 23 spline a left side drop?
For the pcm, I took the fuse box out of the dodge so I'll just power and ground that. I still gotta figure out which wires to use out of the gm harness for the shut down solenoid but that shouldn't be too difficult. Thanks for the input
Old 06-23-2014, 02:31 PM   #4
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: 2nd Gen in 87
Td87, yes you need a transfer case from a 91-93 dodge cummins that was an auto truck which is 23 spline and RH drop. Or use a 241c that came from a gasser of the same era. As for the wiring, you will need to get the wiring schematic for the year truck your donor is and use the required wiring for the engine and trans to work correctly. You don't need the entire dodge wiring harness to do this. If you get me the ESN, engine serial number, from your engine, I can get you a part number and price for the engine wiring from cummins. I'd recommend getting a subscription on eautorepair for the vehicle wiring info. It's $16 per month but you can print out everything you need for your donor.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 06-23-2014, 05:02 PM   #5
Td87
Re: 2nd Gen in 87
I actually bought the Haynes manual for the donor truck. It does come with wiring schematics in the back. I'm just unsure of which wires on the gm harness are going to tie into the dodge harness. Other than the ones for the starter.
