Old 06-24-2014, 12:30 AM   #1
superlifted
superlifted's Avatar
Did i break it
I am currently putting in my motor in my build. got it wired up and was filling to power steering pump when i noticed my electric fans were not working. i do not have a temp gauge hooked up yet. how do i know if i screwed up my motor by running it to hot. 350 cast iron black and heads radiator was full and no coolant boiled out with a 15 psi cap.l
superlifted is offline   Reply With Quote
Old 06-24-2014, 02:44 AM   #2
crazy longhorn
Fabricate till you "puke"
Re: Did i break it
How long did you run it? Also, does she misfire, or run "funky"? Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 06-24-2014, 08:45 AM   #3
superlifted
Re: Did i break it
On and off over 20 minutes. Nothing funky as far as firing. It was idling while I filled the power steering
Old 06-24-2014, 08:51 AM   #4
geezer#99
geezer#99's Avatar
Re: Did i break it
Is it a fresh new never run motor or does it have a few miles on it.
If it didn't puke out of the rad it'll be fine.
Old 06-24-2014, 12:20 PM   #5
truckster
truckster's Avatar
Re: Did i break it
If it ran on an off for 20 minutes, are you sure it even got the coolant temp hot enough to turn the fans on? I doubt you've done any damage at this point.
truckster is offline   Reply With Quote
cooling, hot
