Old 07-01-2014, 01:04 PM   #1
profe56
700r4 or not 700r4
Hi folks: good moning from Chula Vista Ca.
I found two transmissions 1993, one on a Chevy Silverado and one on a GMC trucks. But the harness conector are at the right side of the transmission not at the drivers side like it is on the 1990 I have. Also I just notice do not have the tv cable.
Is this a trans that can be swap or not.
profe56 is offline   Reply With Quote
Old 07-01-2014, 01:11 PM   #2
leftybass209
leftybass209's Avatar
Re: 700r4 or not 700r4
It sounds like a 4l60e. There's no tv cable because the shifts are controlled electronically. It can be swapped with the purchase of a trans shift controller. They don't come cheap though. It's a good transmission, just pricey and more often used for fuel injection setups.
leftybass209 is offline   Reply With Quote
Old 07-01-2014, 01:25 PM   #3
profe56
Thank you Lefty: Yes I just found in this picture I took, there is no tv cable
http://i962.photobucket.com/albums/a...MG_02051-1.jpg
Old 07-01-2014, 01:38 PM   #4
Bigdav160
Bigdav160's Avatar
Definitely a 4l60e
It's not an option unless you want to add a controller plus rig the sensors to make it work.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 07-01-2014, 03:24 PM   #5
profe56
OK thanks for your help I will continue with the 90 I already have.
Old 07-15-2014, 08:48 AM   #6
ericjon262
does anyone know if all 700r4's have provisions for a mechanical speedometer?
'06 2500 HD 4x4. manual transfer case, crank windows.
'88 V10 Suburban 4x4,"The Pig Rig" L05, 700r4, NP208, 4x4 beater camper fun truck project.
My trucks don't leak oil, they mark their territory.
ericjon262 is offline   Reply With Quote
Old 07-15-2014, 11:56 AM   #7
Bigdav160
Bigdav160's Avatar
It can be installed on any of them although all the late ones came with VSS
My Classics:
'73 Z-28 Camaro
'50 Ford Coupe
Old 07-15-2014, 12:14 PM   #8
ericjon262
awesome, thanks!
Old 07-15-2014, 11:41 PM   #9
profe56
Anyways: I already install the 700r4 but if is possible swap a 4L60E, I want to know what to do and what I had to buy in order to do this swap in a future. I could start to collect all the necessary parts for the next time.
Old 07-15-2014, 11:47 PM   #10
profe56
I look for "trans shift controller" and the prices start on 6 hunfred.
Old 07-16-2014, 05:19 AM   #11
JointTech
JointTech's Avatar
yea its not cheap to do electronic transmission without an ECU. i guess the market isnt big enough that the prices have come down on stand alone transmision controllers. Probably wont since most people are going to fuel injection with ECUs anyway. nothing wrong with a good 700r4 .
72 C20 Long Bed
SB350 TH400 14 bolt rear end
Extremely boring build thread
JointTech is offline   Reply With Quote
Old 07-16-2014, 08:35 AM   #12
Bigdav160
Bigdav160's Avatar
Just for my own knowledge, I'm thinking of building a Megashift. By using an old ECM case and connector it can be built for $100-$200
My Classics:
'73 Z-28 Camaro
'50 Ford Coupe
