Old 07-07-2014, 03:45 AM   #1
Russ.W.
Russ.W.'s Avatar
Question Rear sway bar with rear drop shackles on a 67?
G'day all,
I have purchased rear leaf-spring drop shackles from ECE (1.5" drop using stick springs), and I'd like to also install a rear sway/stabilizer bar.
Does anybody know if the ride height change from the drop shackles interferes with installing a rear sway-bar from any of the aftermarket manufacturers? I understand rear sway-bar's weren't a factory option?
C10 is a 1967 2wd Shortbed.
Thanks for your time.
~ Russ
Old 07-07-2014, 08:14 AM   #2
19673ontree
CAN'T FIX NOTHIN
19673ontree's Avatar
Re: Rear sway bar with rear drop shackles on a 67?
I have coils and dropped my truck 5'' in the rear and my rear sway bar fit perfect Id say yours will too ,,
1967 C10 Shortbed Fleetside Small back glass
6 cyl 3spd on the tree 3.08 gears
underdash AC
19673ontree is offline   Reply With Quote
drop shcakles, ece, stabilizer bar, sway bar
