Old 07-11-2014, 10:42 PM   #1
1972GMCsierra4x4
No spark on cylinder NO. 2??
So ever since I put a newer motor in my truck it's been a turd. I know that stock 350s are huge powerhouses, but it was bad enough I needed to check it out. So I pulled my plugs and saw that my number two cylinder was fouled up and wet. Voila, I found the right cylinder. I didn't have the tools to check compression so I tested for spark first and there isn't one. What could be causing this? I'm asking because I am running a Pertronix Ignitor II distributor, and I don't have much experience with them. I know all my wires, plugs and coil are good. Does anyone have thoughts on what could be the problem within the distributor?
1972GMCsierra4x4 is offline   Reply With Quote
Old 07-11-2014, 11:01 PM   #2
Wrenchbender Ret
Re: No spark on cylinder NO. 2??
Its either the plug wire or dist cap.
Wrenchbender Ret is offline   Reply With Quote
Old 07-11-2014, 11:51 PM   #3
geezer#99
geezer#99's Avatar
Or a cracked sparkplug!
Old 07-12-2014, 12:13 AM   #4
jjzepplin
jjzepplin's Avatar
Timing light will tell you the culprit.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 07-12-2014, 09:58 AM   #5
68gmsee
Active Member
68gmsee's Avatar
Yeah, I've always used a timing light to test for spark in my vehicles. I just clamp it on the plug cable.
You can also hold the plug against a grounded surface and see if it sparks when cranking. If it does, then a compression check, or better yet, a leak down test would tell you if it's burnt valve, rings or valve guide fouling the plug. I've also found more new defective spark plugs recently than I recall ever having.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
chevy, dead cylinder, distributor, electrical, small block
