Old 07-20-2014, 03:12 AM   #1
64chevtruck
70 GMC in progress.
Hi guys, I been hanging around the 60-66 forum messing with my 64. But it is my mission to collect a Chev or GMC truck from every generation.
Meet the second in the fleet, my new 70 GMC. Its got a 1976 305 w HEI, a 2 barrel carb, 3 on the tree, Leaf springs in back on this one, so I got to get a flip kit to take it down south. This one wont go all the way down for now, going to just drop it cheep and drive it. Ill probably bag it later.
Now I wasnt too happy to hear it had a transplant 305 in it, that is until I drove it, Now Im amazed how much poop that thing has, and all is forgiven,
On to the pics.
64 C10 Fleetside LB 4 Sp/292 Build http://67-72chevytrucks.com/vboard/s...d.php?t=602438
70 GMC 1500 Fleetside LB 3OT/350 Build http://67-72chevytrucks.com/vboard/s...83#post6767983
76 GMC CCLB Dually Build http://67-72chevytrucks.com/vboard/s...d.php?t=691612
79 GMC 3500 Fleetside LB 454/400
90 Suburban Silverado 4x4 350/700R4
97 1500 Cheyenne Short Fleet 350/5sp
64chevtruck is offline   Reply With Quote
Old 07-20-2014, 03:22 AM   #2
64chevtruck
Re: 70 GMC in progress.
It came with no headlight rings or front bumper, and since the front of these GMCs are my favorite part, I knew right where to start.
New rings
New bumper *(only hanging there in the pic, waiting on new boltz)
Fresh flat black on the grill,
Shaved drivers mirror, installed a peep.
Im not gonna lie, I got it bad...... I just got another 69 GMC 1500 too! You see her in the background next to my 64. It wills stay stock height for now with the stock 350 automatic and 350 CI.
Roll pan inc next!.
Old 07-20-2014, 03:37 AM   #3
64chevtruck
Rear bumper removed, Roll pan installed, bullets, licence plate lights, Flip kit with blocks in back, front springs cut, rims satin black, Large moons installed,
YEA!
Old 07-20-2014, 06:40 AM   #4
SuperC10Tex
SuperC10Tex's Avatar
Got to love those 4-eyed projects!!! Oh! just checking, you like the 72' grill look on your 70'? Keep the pics coming.......
1970 GMC Sierra Grande CST SWB Fleetside "Texas Touch"
"An intellectual is a man who takes more words than necessary to tell more than he knows"
SuperC10Tex is offline   Reply With Quote
Old 07-20-2014, 07:35 PM   #5
64chevtruck
Howdy Tex. Thank you and I didnt even know it had a 72 grill in it !
I been focused on chevs all my life and still dont even know the diff between the GMC grilles, I will be doing my home work on that for sure, Thank you for pointing it out.
Im headed to your build thread now to check your ride thank you for your interest,.
Have a good week
Old 07-20-2014, 08:05 PM   #6
64chevtruck
Heres a pic of the DJM flip kit I put in, They sent the U bolts about 1.5 inches too long, so I made up some lowering blocks out of some super hard plastic I had and got all the drop I could out of it. They should hold up but if not Ill keep ya posted.
I also removed the thick bottom overload spring on each side and that gave me another 5/8 of U bolt/Drop to play with as well as letting the springs relax a bit more,
I removed the bump stops in back and wrapped an inch thick strip of rubber around the rear end on each side for now ( not pictured) to keep the axle from banging on the frame, It sits just barely above the stops all the way around so the ride is not smooth for now.
I got a large step notch to put in the back asap, and Ill get some bags up front with a few more mods.
Have a good week.
Old 07-23-2014, 11:47 PM   #7
64chevtruck
Ha damn, I lost a hose the other day and overheated er, Pluming white smoke..... Hope its just a head gasket. If not..... Ill slam a different motor in asap.
Thanks for the feedback Tex.
Have a good week
Old 07-25-2014, 11:26 AM   #8
64chevtruck
Pulling the hood and getting ready for a change.
Have a good weekend.
Old 07-27-2014, 09:33 PM   #9
thelonerife
thelonerife's Avatar
Love the truck. And that its a GMC. Whats the new motor going to be?
thelonerife is offline   Reply With Quote
Old 08-17-2014, 03:52 PM   #10
thelonerife
Any progress?
Old 08-17-2014, 07:45 PM   #11
64chevtruck
Hi and thank you for your interest,
I actually just got the 305 back together today, I ended up puting new head gaskets on it, found a small crack in the center of the head on one side but it does not go into the firing chamber, It goes from a water port to a head bolt. Its running now, Ill put the short headers on it and get the exhaust done, then drive it like I stole it. If something breaks again ill just bolt a new motor in there.
Got upper bag plates, compressor, 4 bags, Drop shackles, Step notch, and a few other things for it on the bench. Ill post pics asap.
Have a good week
Old 08-17-2014, 07:51 PM   #12
thelonerife
Great. I'll be watching
Old 08-25-2014, 12:42 AM   #13
64chevtruck
Howdy, Ok so the 305 runs but Im unsure of it, so I bought an 85 chev 350 for $300, Im almost done cupping the lower control arms, Tomorrow Im mounting upper bag plates and getting the front bags mounted.
Soon as the front end is done Ill get on the motor change asap. Ill get some pics tomorrow,
Nothing special but heres a shot of my new to me 350 and other parts Ive got waiting,
Have a good week
Andy
Old 09-27-2014, 03:53 AM   #14
64chevtruck
After I got done cupping the lower control arms, and had the motor out, I was looking at the crossmember and could not think of a reason not to pull it out at this time for a 1.5 inch pancake. There would never be a better time to do it so I did.
This one went smooth compared to the first one I did on my 64. I installed rubber grommets for the air line to pass through in this crossmember.
This time I assembled the LCAs and bags/bag plates before I mounted the crossmember back up.
Have a good weekend
Old 09-27-2014, 04:19 AM   #15
64chevtruck
After I mounted up the front end assembly, I figured Id notch out the upper left control arm so it doesent rub on my steering shaft when its dropped all the way down.
The bottom pic here shows the truck lowered down to where the wheels hit the inner fender wells, It will go lower after I cut the wells out but ill focus on the back before I make the front go any lower, also shows the beauty rings I found in the back of my shop, So happy they fit!
I still need to make a switch plate, and put a compressor onboard. then back to the back...
Old 10-09-2014, 02:33 AM   #16
64chevtruck
So I mounted up a small compressor in the bed and installed a new aluminum radiator, also installed some kevlar heat shields *not pictured) for the plug wires.
I made a switch plate that covered up where my dash was butchered out for my 2 switches,
This truck has leafs in back so only 2 front bags for now, Ill see how low I can make it go with leafs in back for now.
Next step is to remove the bed and install a 10 inch step notch, some drop shackles, and to move up the stock leaf hangers 4 or 5 inches.
I bought some Mickey Thompson Sportsman tires with deep dish rims to run on it, they are made to tuck all the tire up under the vehicle but after looking closer I see the tires will hit the leaf springs because they are so deep.
I may have to run em on my 64 that has coils in back, we will see.
Have a good week,
Old 10-09-2014, 08:36 AM   #17
BigDaddyV
BigDaddyV's Avatar
Very sweet truck and I'm liking what you are doing with her! Keep it up!
J. Vess, 6'6", Gearhead, Welder, Fabricator, Nutcase
1955 Chevy Stepside "Dudley"
My daily http://www.67-72chevytrucks.com/vboa...d.php?t=760288
1972 Chevy C10, Project "Chevro~Layed out" Nether Storm
Build Thread http://67-72chevytrucks.com/vboard/s...23#post6007523
BigDaddyV is offline   Reply With Quote
Old 10-09-2014, 09:42 AM   #18
mikewoods
mikewoods's Avatar
Looking Good! Do you mind sharing the part number of the flip kit you used?
"The Mustang’s front end is problematic, get yourself a Firebird. "- Red Forman
mikewoods is offline   Reply With Quote
Old 10-13-2014, 04:09 PM   #19
64chevtruck
Thanks fellas.
Mike I done know the part number of the kit I used but if you search DJM Flip kit you will see it for sure, they were one of the few peeps who carried the 67 72 kits.
No new progress I been changing the motor on my geo tracker, and fixing the front end on my Moho.
I hope to be back on my green machine within a few days.
Have a good week.
Old 11-17-2014, 05:39 AM   #20
64chevtruck
Hi, I finally got the bed off my GMC and am getting ready to put a 308 rear end in it, Install the large step notch in the frame, extend shackles, and raise spring hangers.
I cant wait to see if I can get the back down to a ride height I like.
Did I mention I picked up a few more trucks recently in my mission to have a chev or gmc truck from each generation>>?
Ol Yeller, 69 GMC LB1500 350/350
Big Red, 79 GMC LB 3500 454/400
(No Name Yet ) 97 Chevrolet SB 1500 350/5sp
Im excited and cant wait to play with em some more, Now looking for a 47-53 Chev or GMC truck in the Oly Wa area.
Ill post pics of the rear mods on the Green truck asap,
Have a good week
Old 11-17-2014, 02:24 PM   #21
64chevtruck
Big Red
Old 12-25-2014, 02:55 AM   #22
64chevtruck
Hi Guys, MERRY CHRISTMAS.
Ok time to focus.
Been working on my Green Truck.
Got the step notch welded in, Came up with a plan to remove the leaf spring and shackle perches and raise them 6 inches. This mod cost 40 dollars at the local fab shop, they cut 4 6x8 plates, and 8 2x6 plates for me out of 3/16 steel and I welded em up. This gave me 6 inches, the flip kit gave me 6 inches, and the blox added another 1.5 inches, for a total of 13.5 drop from stock. I think the blocks will have to come out but we will see.
You see them clamped on the raised area of the frame in the last pic, and my new 308 rear end lurking down below,
Got to replace the pinion seal, and switch out the 5 lug axles with the stock 6 lug ones out of my old rear end.
HAPPY HOLLIDAYS
Old 12-25-2014, 03:22 AM   #23
trac209
Dude seriously cool build!!!!!!
trac209 is offline   Reply With Quote
Old 12-25-2014, 05:46 AM   #24
64chevtruck
Thanks Man! Much apreciated.
First pic here shows the perches dialed in and bolted up solid,
Last few pics show the lowering blocks removed because the truck sat too low, and they were made of plastic.
The 308 rear end installed, the overload springs put back in place...
And me dreaming about running huge tires on one of my trucks...... They would have to be run on a truck that has trailing arms, the leafs get in the way of em.
I had to change the yoke on the pinion so it would work with my U joint on the drive line, still need to switch out the axles to the 6 lug, Should have it all done tomorrow,
Replace cab corners next, Then cut the bed floor out and mount bed, then cut out or remove inner fender wells in front so it drops all the way down,
Happy Hollidays
Old 12-25-2014, 11:42 AM   #25
BigDaddyV
BigDaddyV's Avatar
Thumbs up Re: 70 GMC in progress.
Wicked !!!!
I love the stance and the way you made the Leaf brackets.
Keep up the good work. That sucks you cant run the Fatties on the back though.
Maybe the Yellow one?
