Ls swap headers????
Guys post some pictures of your engine mounts, trans crossmember, and your headers. I have a 69 c10 and I need some headers for it thy will fit with no modification. Now that I live in the real world explain what you did and how you did it to make it fit. Thank everyone.
#2 | |
Re: Ls swap headers????
Old member
I did a 6.0 LS swap with stainless work headers with no mods. Just a little tweeking on passenger side frame rail. When you look at it it's impossible to see it.
![]() Link to more pictures. ![]() http://67-72chevytrucks.com/gallery/...y.php?cat=1979
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Stainless work? Is that the brand do u have a part umber or website. I'm not trying to brake the bank also.
![]() Join Date: Sep 2005
I used trailblazer ss manifolds with the down.pipes that ca me withyour motor and they cleared perfect
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
![]() Join Date: Jul 2010
The Doug Thorley's seem to be very popular with the LS swaps. They fit really well and look nice.
Mark 1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20" My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609. My first start up http://youtu.be/R899YQ1OcjU |
#7 | |
Old member
![]() Quote:
![]() http://www.hawksthirdgenparts.com/pr...Collector.html
Another vote for Doug Thorley's, POL tubular motor mounts and adapter plates, slid right in with no clearance issues at all.
70 CST, 6.0/ 4L80E in the works. *Custom harness by 68 Short Step* |
Hedman also makes LS swap headers specifically for the C10 trucks. We are a dealer, so let m know if we can help you out.
How much?
Yea I need a set for my truck to ^^ how much lol
1969 C20 CUSTOM "RUMBLEr" |
As of now I will be using early classic mounts and trans crossmember. My factory exhaust manifold r cracked at welds. However what I am looking for is something nice, fairly cheap that will get the job done without turning into a hack job.
#13 |
Another member told me these were the best choice are far as cheap and effectiveness. Any input?
http://www.ebay.com/itm/like/301143029583 |
#14 |
#15 |
I don't really want to spend this much but are these easier or a better route?
#16 |
#17 |
Bump
#18 |
The main thing I don't like about long tube headers besides the cost is their only advantage in flow performance is seen above 6000 RPM typically and every one made the collectors hang down below the frame rails.
Having done many hot rods and my 2nd GMC truck I wanted the entire exhaust up inside the frame rails. New Camaro owners love installing long tube headers on their New car, so the LS3 OEM exhaust manifolds are every where used and Cheap. Mine came off a crate engine never used. The OEM 5.3 truck manifolds hit the frame rails on these old trucks, these 2013 Camaro LS3 manifolds tuck inside the frame rails, you use the stock Camaro head pipes cut-off in front of the cats, preserving the O2 sensor bungs. My exhaust is run where I want it, No clearance issues. The LS3 Camaro made in stock configuration 436 HP with these manifolds. I'm happy, just my two cents
68 GMC SWB Vortec 5.3 98 Chevy Blazer ZR2 94 Mazda Miata, LS2 6 speed, sold "No matter what happens, nobody gets out alive" |
#19 |
I think I'm going to try and find some. Thanks do u you happen to know where any are for cheap?
#20 |
Keepin an eye out
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
#21 |
Keepin an eye out
Look on Corvette forum c6 parts section/
#22 |
Here is a few options from Hedman.
Uncoated, Mid Length, 1.75" Primary: $375 shipped Coated, Mid Length, 1.75" Primary: $665 shipped |
#23 |
Installed in a customers truck
#24 |
Really nice work, especially for desert dwellers
![]() Is that a radiator you guys sell? Stock mounts?
#25 |
I used the pacesetter TBSS longtubes on my '66 lwb
stock sbc pedestals and $40 ebay adapters needed to trim the frame 1/4" with a cutoff wheel but otherwise I'm happy. they were like $250 from amazon fyi, they exit tucked way up in the frame had to use s-bends to go under the trans cross member (pre 75 dual exhaust style one) |
