Old 07-26-2014, 01:41 PM   #1
Lineman
Resto under way, Door Questions 63 GMC
I need help with some Door questions.
The metal work is done on my 1963 doors. Any real nice regulator set ups out there?
Is a power set up the way to go or are they too much trouble?
I need to buy the glass, is it all the same wherever you get it? Same as the felts anad rubbers?
I saw some latches in the magazine and they advertize they shut like a new car door. Is there anything to that?
I am trying to stay as close to original as function will allow, I hope to drive this truck a lot.
Thanks for the help.
Jay
Lineman is offline   Reply With Quote
Old 07-27-2014, 02:38 AM   #2
Captainfab
60-66 Nut
Re: Resto under way, Door Questions 63 GMC
I can't answer your questions, but here's a bump for you.......
Old 07-27-2014, 06:51 AM   #3
MikeS.
MikeS.'s Avatar
For window felts and rubber use Steele brand. More expensive but much better quality.
Past Master
Triluminar Lodge #117 GL of WVa
My 1963 4x4 Suburban build;
http://67-72chevytrucks.com/vboard/s...d.php?t=531274
My Gallery, now with pics of my 1966 C30 motorhome.
http://67-72chevytrucks.com/gallery/...&ppuser=103447
MikeS. is offline   Reply With Quote
Old 07-27-2014, 01:01 PM   #4
Lineman
Thanks,
Anybody got any info on regulators or power window set ups?
Old 07-27-2014, 01:22 PM   #5
bhc41051
bhc41051's Avatar
You won't go wrong with Steele, I've heard they buy from Precision so you might check them out. http://precisionrestorationparts.com/ I bought my glass from a vendor, the vent glass fit and the window glass didn't. So I'd just have the glass cut by a local glass shop.
bhc41051 is offline   Reply With Quote
Old 07-27-2014, 03:31 PM   #6
ls60apache
hello! I will be buying a power window set up from nu-relics in north Carolina,looks like a well made regulator and they use gm window motors.i think electric life makes a setup,but they look flimsy to me.jmo. good luck.
ls60apache is offline   Reply With Quote
1963, doors, gmc
