Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork > Detailing
Old 08-10-2014, 05:38 PM   #1
Senorx
Senorx's Avatar
Engine Degrease and Cleaning
I will be attempting to degrease and clean up my engine bay for the first time tomorrow morning. Any tips or tricks? Dos and Don'ts? Anything not to get wet? Anything not to get cleaner on? Anything that needs to be covered? I have a pressure washer too. I also purchased some "Super Clean" which I was told is like "Simple Green". I'm still a total newbie and learning as I go along. Is it weird that I'm really excited to get started?
I'm looking to replace the air filter with a K&N Filter and new top too. I'm tired of looking at what's on top right now.
Senorx is offline   Reply With Quote
Old 08-10-2014, 05:40 PM   #2
Old Truck Man
Old Truck Man's Avatar
Re: Engine Degrease and Cleaning
Get rid of the clear plastic gas filter. those are a real fire hazard.
Old Truck Man is offline   Reply With Quote
Old 08-10-2014, 05:43 PM   #3
Senorx
Senorx's Avatar
Will do. I'll be running out to Napa in the morning and pick up a new filter. Is it a real simple install?
Old 08-10-2014, 05:57 PM   #4
67Steven
67Steven's Avatar
Should just be 2 hose clamps and done. I'd replace the clamps at the same time, unless they look good/new.
1972 Blazer build: http://67-72chevytrucks.com/vboard/s...d.php?t=615744
67Steven is offline   Reply With Quote
Old 08-10-2014, 06:00 PM   #5
67Steven
67Steven's Avatar
One other item- Be careful with Castrol super clean at full strength. It will etch any unprotected aluminum surface, and strip wax off of paint. It is awesome stuff to use, though.
Just don't breathe in the mist!
Old 08-10-2014, 06:03 PM   #6
pwdcougar
pwdcougar's Avatar
A new steel filter should go on easy. Just unscrew the hose clamps or squeeze the spring type clamps on your present filter. Use new clamps. Check the present fuel hose and make sure it isn't deteriorating. Might be worth your while to get a couple more feet of hose and replace whats there. Not sure of the size 3/8ths? 5/16ths? The inlet side of the fuel filter on my bench is 3/8ths. Best bet is to pull of the present filter and match it up at the auto parts store. Personally I don't like to have much rubber fuel line. You might want to consider replacing what you can with steel
I've used Gunk brand engine degreaser with success in the past. You can get it at Walmart.
Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those"
1969 Mercury Cougar Standard 4 speed
1969 Mercury Cougar XR7 convertible
1970 4WD Chevrolet Suburban
1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997)
pwdcougar is offline   Reply With Quote
Old 08-10-2014, 06:14 PM   #7
asolde
asolde's Avatar
Get some carb cleaner, stuff a rag in the throttle opening and wash the carb off with the carb cleaner, then put a bag over it to keep the water out. Put a bag over the distibutor cap. Spray it down with you degreaser let it soak in for a while. Protect your paint on your fenders and cowl with towels. I have used gunk and regular old oven degreaser. Pressure wash it off. Uncover everything and get it started up. Good luck
1972 cheverolet K5 CST Blazer
350/auto/AC/PS/PB/Aux Batt
From Medford, Oregon
asolde is offline   Reply With Quote
Old 08-10-2014, 07:29 PM   #8
jaros44sr
jaros44sr's Avatar
Not wierd at all...you re a motorhead, and we get excited when we get to do mechanical stuff
When you replace the fuel filter, if it is a plastic type don t use worm drive clamps. They can squish the inlet and outlet closed. Just use spring type clamps (OEM) Use as much steel fuel line as you can make up, or go to the junkyard and get a used one
Good Luck, ^^^^^^^^^and all great advice, pay attention young grasshopper
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 08-11-2014, 10:12 AM   #9
Old Truck Man
As for the fuel filter. Myself I prefer a steel line between the fuel pump and carb. the sintered bronze factory installed in the carb inlet does a remarkable job. I install a steel cased filter between the gas tank & fuel pump. I started a thread about this subject. and it was discussed at length on another thread about a truck that caught on fire. I strip as much rubber and plastic away before engine cleaning. I remove the dist cap & wires. alternator andany wiring I can easily unhook. For really crusty stull that don't come off with normal solvents is use oven cleaner Be careful not to let it set on aluminum very long.
Old 08-11-2014, 10:14 AM   #10
Old Truck Man
The plastic and glass filters are a fire waiting to happen.
Old 08-11-2014, 11:09 AM   #11
jaros44sr
jaros44sr's Avatar
With all due respect Sir, i disagree with 1/2 your statement! The plastic shouldnt shatter as the glass does, it will only cause a problem if installed in correctly.....as would any device
I do however agree with you on the OEM, it does a great job, BUT, i have seen guys cross thread the fine threads on the carb body. So infact, the job becomes much easier, with less potential big problems, with a external filter of the proper design
As with any install on these ol trucks, its up to the installer to do quality work
SAFETY FIRST
AS usual, off topic
Jim
Old 08-11-2014, 11:15 AM   #12
Senorx
Senorx's Avatar
So was the original fuel filter suppose to be installed between the fuel pump and fuel tank? Was it originally installed maybe along the frame rails on these K5s?
Old 08-11-2014, 01:16 PM   #13
Senorx
Senorx's Avatar
Found this under a rattle can paint job on my driver's wheel well? Super Clean strips rattle can paint come to find out. LOL. Does this mean it's an original wheel well. The sticker looks pretty well preserved. Wondering if it's a reproduction?
Finding surface rust covered by rattle can. Should I sand it off and re-paint?
Old 08-11-2014, 02:21 PM   #14
Old Truck Man
I started a thread about filters installed between the pump and tank versus the pump & carb. Go there and we can debate the issue. That plastic when installed between the pump & carb gets old and eventually the pump pressure will cause it to crack spraying fuel under the hood. If a carb inlet becomes cross threaded all is not lost. there is a oversize self tapping replacement inlet fitting available. Ive never cross threaded one.
Old 08-11-2014, 02:24 PM   #15
leddzepp
Moderator
leddzepp's Avatar
POR Marine clean is the best degreaser I have ever used. I suspect it is bilge cleaner. Makes simple green look like water.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
leddzepp is offline   Reply With Quote
Old 08-11-2014, 02:32 PM   #16
Old Truck Man
There where some that did have a canister filter mounted along the frame rail. Most have a filter sock on the inlet inside the tank. and the sintered bronze or paper element inside the carb inlet. Putting rubber hose and a filter between the fuel pump & carb is a fire hazard. The hose becomes old and the plastic and glass see through filters can burst. Ive never seen a GM factory installed filter attached with rubber hose installed between the fuel pump & carb. a solid steel line is what came from the factory on trucks. I cut the rubber line on the inlet side of the fuel pump and install a wix steel cased filter at that location. I also use the factory sintered bronze filter in the carb inlet.
Old 08-11-2014, 06:05 PM   #17
jaros44sr
jaros44sr's Avatar
No need, i ve spent enought time on this topic
SAFETY FIRST
AS usual, off topic
Jim
