08-12-2014, 10:43 AM | #1 |
Transmission cooler lines
All,
I am on the homestretch of a 5.3/4l60e swap into 1987 squarebody. I bought universal 5/16 hardline to bend and run for the tranny cooler lines. The problem is, when i tighten the fitting into the transmission, they bottom out on the transmission housing before getting tight...is there something im missing? The factory lines for the 4l60e were held in using a clip correct?Do i have to use that style connection?? Thanks in advance! |
08-12-2014, 11:07 AM | #2 |
Re: Transmission cooler lines
the case threads are 1/4" npsm not npt.
i googled "4l60e trans fittings and came up with a ton of options" I personally used AN fittings & line since I had a ton extra from the fuel lines. |
08-12-2014, 11:49 AM | #3 |
Hmmm, the fitting on the end of 5/16 line is 1/4 npt?? It screwed right in, just not enough threads to tighten up...
08-12-2014, 12:01 PM | #4 |
i just went through this yesterday. Order Dorman 800-755 from any parts store. just goes in between the line and the trans. no more fluid pooring out.
08-12-2014, 12:03 PM | #5 |
this one.
08-12-2014, 12:21 PM | #6 |
Thats what I was hoping for. The 5/16 line threads right into that? Thanks
