Old 08-12-2014, 07:52 PM   #1
71ChevySS(straight6)
Arrow Can I (should I) stick a 68 clip 'n' cab on a 71?
Hi fellas! So, here's the situation: I was browsing Craigslist and found a cab and front clip for a '68 C/10, and the guy only wants $400. Mint condition, from what I can tell in the pictures, and has shaved door handles, a frenched antenna, a smoothed filler neck hole, and all the supports as far as radiator support and whatnot, but it doesn't have wheel wells. The passenger vent window is there, but that's the only glass in it. (Could I just yank the doors and glass off my truck, or are they different?)
It definitely needs painted - bad. But I can do that, I have a HVLP gun, just need to get my big air compressor running and do some practice on old tin or something.
As far as what all interior is in it, there isn't anything but a brake pedal. I could strip the guts of the 71 cab (minus the gauge cluster) and stuff them in there.
Here's part of the issue: the cab has a low center hump, and the one currently on my truck is a high hump. What will that affect? Also, will mounts be different? Another issue is how hard will it be to pull the cab and clip off my truck and install these, then install all the interior stuff and attach everything to the firewall? Could I just replace the front clip and leave the cab alone alltogether?
Thanks a bunch in advance!!!
71ChevySS(straight6) is offline   Reply With Quote
Old 08-12-2014, 09:14 PM   #2
R.L.
R.L.'s Avatar
Re: Can I (should I) stick a 68 clip 'n' cab on a 71?
As far as I know everything will interchange, the only differences being. The emergency brake lever on older models were replaced with a brake pedal. The steering wheel is different. Maybe upholstery on the seat? I think the front cap and hood will bolt right up. The glass and everything else is the same. Just put the front clip on there and go. There might be something in the electrical system that changed trough the years but I'm not sure of what it was.
R.L. is offline   Reply With Quote
Old 08-12-2014, 09:18 PM   #3
R.L.
R.L.'s Avatar
I just read where you will also need to use the 67/68 radiator support bushings
Old 08-12-2014, 10:15 PM   #4
67ChevyRedneck
67ChevyRedneck's Avatar
A/C and non A/C cabs are different where the heater box and/or A/C box mounts to the firewall on the PS.
You can trace the high hump hole in your cab, cut out the hole in the new cab, mark and drill the holes, and bolt the high hump cover on the new cab. You can get fancy and weld the nuts to the floor after you've pre fit everything.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 08-13-2014, 12:21 AM   #5
Thanks for the help guys.
R.L., my truck has a middle bench out of a '92 Suburban that my dad switched into it in college
67ChevyRedneck, how'd you know it was an A/C cab? lol
That floor pan thing is a pretty good idea. I never thought of that. We may be rednecks, but we have one thing a lot of city boys don't have: ingenuity.
Here is the link to the Craigslist post, I just noticed the headlight buckets are different than stock... http://seks.craigslist.org/pts/4612737287.html
Old 08-13-2014, 01:10 AM   #6
68shortwide
68shortwide's Avatar
The only real problem I see if you use the red cab is titling issues since it'd be a different vin tag. But if you use your own cab the 68front clip should bolt on without a problem if you use the advice in the posts above mine.
Jack
Personal Fleet: Family Fleet:
1955.5 Panel 1959 Apache
1968 ShortWide
1969 ShortStep
68shortwide is offline   Reply With Quote
Old 08-13-2014, 08:47 AM   #7
67ChevyRedneck
Not only that, the fenders have been ruined as well. Look at the leading edge, completely different than stock. Looks like the DS door has a huge dent in it too. It also appears to me he welded the cowl to the A-pillar and the top of the fenders. You may want to pass on this one...
Jesse James
Project "On a Dime"
Old 08-13-2014, 09:06 AM   #8
67swb72klb
67swb72klb's Avatar
looks like another abandoned custom job
just depends on what you want the cab does look solid though
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 08-13-2014, 09:27 AM   #9
motorcritter
motorcritter's Avatar
That cowl 'modification' may be more hassle than it's worth. The stacked headlight thing is pretty unique, though. That there's no title, that's another potential headache, too.
If 'that which does not kill me, makes me stronger', then I should be Superman by now!
motorcritter is offline   Reply With Quote
Old 08-13-2014, 10:52 AM   #10
I don't know about the fenders being ruined, I kinda like how they look (but I really want those marker lights back...), but the grass is creating an optical illusion making the door look dented.
As far as the cowl being welded to the fenders and A-pillar, that wouldn't be that big of a deal. If I need the fenders to come off, they make this thing called an "angle grinder" that would do the job lol
You can tell it does need at least one cab corner, though, and I have a feeling they're both missing. But, you can get those for fairly cheap.
Could I just take the vin plate off my '71 cab and replace it on the '68 cab?
Old 08-13-2014, 01:29 PM   #11
RenoKeene
Florida Edition
RenoKeene's Avatar
That whole thing is a mess.....keep looking.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 08-13-2014, 01:32 PM   #12
Bad Jackson
I would
I work with tools.
Bad Jackson is offline   Reply With Quote
'68, '71, cab, front clip, install
