Old 08-21-2014, 01:28 AM   #1
edgooch
8.1L and 4L85e swap into a 1972 Custom Camper 4WD
After thinking it about for 8 years, the swap has begun. My '72 looks good, but it has the original engine in it. The odometer shows 02,XXX miles. I don 't know how many times it has rolled over, but that old 350 is tired. The 8.1 and 4L85 are out of a 2003 3/4T Suburban. The engine has 80,000 miles on it and the tranny has 10,000 miles on i.
I have checked the engine carefully and while doing so, installed a new mid range Comp Cam and lifters. The ECU is off at Howell Engine Development to be reprogrammed.
After assembling parts, the first step was to move the gas tank out of the cab and put it behind the rear axel. I pulled the bed off using an engine hoist and a 4x4 timber "H". Two bags of fertilizer provided the needed balance weight.
The tank is for a 72 suburban. After removing the spare tire brace, it fits right in. The third brace from the back under the bed has to be cut down (up?) to fit over the tank.
More Pictures tomorrow.
72 Custom Camper 4x4
04 2500 HD - 8.1/Allison
edgooch is offline   Reply With Quote
Old 08-22-2014, 11:15 AM   #2
edgooch
Re: 8.1L and 4L85e swap into a 1972 Custom Camper 4WD
Lifting the bed off was a one person operation, with the use of an engine hoist and 4x4 frame.
Old 08-22-2014, 11:23 AM   #3
Mindl3ss
Mindl3ss's Avatar
This is my plan too, but I was figuring on 2x4 instead of 4x4. Now I'm second guessing that. Short/wide box, wood bed.
I'm looking forward to the progress on this thing. That 8.1L is huge!
In the garage:
The project - 1968 C10 Short box
The hauler - 1994 K1500 Silverado Z71 - Sold
2015 Colorado Z71
Mindl3ss is offline   Reply With Quote
Old 08-22-2014, 11:28 AM   #4
edgooch
The fuel tank (from LMC Truck) is installed, ready for plumbing. Couldn't have done it without the excellent help of my grandson, Zach. A significant modification is the addition of an electric, in-tank fuel pump. It is an Airtex 3501M and is the specified replacement pump for the engine/tranny donor vehicle. It is spring loaded, so it fits perfectly (height wise) in the LMC tank.
Old 08-22-2014, 11:59 AM   #5
edgooch
I would worry about the 2x4 twisting or bending.
Old 08-23-2014, 12:39 AM   #6
edgooch
The bed brace has now been cut to accommodate the tank. I marked the cut line with a Sharpie then cut it out with a cutoff wheel on an angle grinder. Then I welded the bottom of the brace back on. Note the 2" hole in the brace to the right of the bed bolt. The hole is angled up and to the right. It is lined with 2" tubing and both ends are welded all the way around. The filler neck hose will go thru the hole and up to a new door in the side of the bed just behind the left rear wheel well.
Old 08-23-2014, 09:21 PM   #7
tommys72
tommys72's Avatar
I'm gonna watch this one
United States Marine Corps 2000-2011
Iraq and Afghanistan veteran
Just living life now and enjoying it and my wife, daughter and son
tommys72 is offline   Reply With Quote
Old 08-23-2014, 10:27 PM   #8
farmtrucks
farmtrucks's Avatar
Just a thought but, -- DONT ruin your bed by cutting a hole in it for the filler neck -- put it behind the marker light. I put mine in a stepside and it was super easy, a fleet side will be a little tougher because its a little tighter but definitely doable. Search "gas filler marker light" - there are several threads on here.
farmtrucks is offline   Reply With Quote
Old 08-25-2014, 08:51 PM   #9
edgooch
Tommys72,
I am looking for input and ideas as well. I have never done a project like this before. Thanks for you service.
Old 08-25-2014, 08:56 PM   #10
edgooch
I am working on "the right solution" for the filler door. I saw this truck at the Good Guys show in Tacoma recently and loved it. It sort of makes you say, "did that come that way?". I have delayed that decision while I look at alternatives. Thanks for the ideas!
Old 08-25-2014, 09:08 PM   #11
Xeen
Xeen's Avatar
Personally I don't think it's "ruining" the bed because there is nothing done by adding the fuel door that can't be undone at any time by a good fabricator.
I agree though that on a 68-72 truck the marker light approach is a good one.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 09-02-2014, 09:28 PM   #12
edgooch
I have made some progress since my last post. The gas tank is installed, including fuel lines and fuel pump wiring. I may have to move the wiring around when I put the bed back on, but that will be easy.
Old 09-02-2014, 09:31 PM   #13
edgooch
While I was working around the back of the frame, I installed some new Monroe Gas Magnums.
Old 09-02-2014, 09:35 PM   #14
edgooch
I have also been busy at the front of the truck. The bumper, grille, hood, fenders, radiator and radiator support have all been removed. The old engine is ready to come out.
Old 09-02-2014, 09:49 PM   #15
edgooch
I have decided to solve the new engine crossmember problem by purchasing the DIY4X crossmember kit. A link to the product is below. The picture on their website is old. The kit one includes a removable center section. That section is the only thing that will have to be modified to fit the 8.1 oil pan. Here is a picture of one done for a 72 Blazer. You can see that build on the CK5 forum. Look for Igor.
http://diy4x.com/cart/index.php?rout...&product_id=80
Old 09-04-2014, 12:45 AM   #16
edgooch
As I took the front clip off of the truck, space quickly became an issue. I had no where to store the big body parts. I was also concerned that moving them around was going to surely result in damage. The simple solution was to store the fenders, hood and other parts in the bed. I built a wood rack the allowed the parts to be stacked. So far, it has worked well.
Old 09-04-2014, 06:38 PM   #17
mx289
mx289's Avatar
Very sharp looking truck.
Great build you have going here.
If you ever need info on the 8.1 swap,
DirtyLarry is sort of a guru on these swaps.He posts alot in the 4x4 section.Very smart guy.
Tom
71 K2500
71 K5 Jimmy
mx289 is offline   Reply With Quote
Old 09-30-2014, 11:00 PM   #18
edgooch
Time for an update. I have managed to make a little progress on this swap. As shown below, I finished installing the new fuel tank behind the rear axle, including the fuel line, return line, wiring for the in-tank pump and a wire to the original fuel gage in the truck.
I also swapped the original vacuum boost Master Cylinder out for the hydro boost MC from the donor 2003 Suburban. It took a little welding and grinding, but in general, it fit in nicely.
Spend some time contemplating my choice to use the original drive by wire throttle body, which requires the use of the also original huge accelerator pedal. After studying the pedal assembly, I determined that it did not need to be huge. the bulk of the pedal assembly is dedicated to the ability to perform an adjustment of the pedal height (in Suburbans with "Driver 1/Driver 2 systems). That feature is not applicable to my 72, to I cut away the unnecessary pedal mechanism and grafted the original pedal onto the now much smaller assembly. It is installed and feels just right.
I also finished striping away the parts on the frontend that were either in the way or being replaced. She is ready to begin reassembly.
Old 12-22-2014, 12:56 PM   #19
edgooch
Quick update. This build is going slow but steady. The 8.1, 4L85e tranny and NP241C transfer case are all mounted and aligned with the diff. No drive lines yet. Working on linkages and accrssories. Transmission shift is hooked up and works perfect. Looking for a shifter stick for the transfer case so I can finish fabing linkage.
I have run into two issues not solved yet - exhaust and power steering. Stock 8.1 exhaust manifolds won't fit. I tried a pair of new stock spec reproductions of 70's era 454 manifolds and they are not close to fitting. Now I am looking for a pair of good used original 454 manifolds.
Power steering - the truck is a factory air original so it is important to make it work with the new motor. Taking Dirty Larry's advice, I installed the accessory brackets on the front of engine from a 2004 Topkick 4500. That also requires switching to the water pump, harmonic balancer, tensioner, A/C compressor and power steering pump from the Topkick. So far, I have found everything but the power steering pump.
Old 12-22-2014, 12:58 PM   #20
edgooch
A couple more pictures. I can't seem to post more than one photo at a time so I'll do a couple of posts.
Old 12-22-2014, 01:00 PM   #21
edgooch
Exhaust clearance
Old 12-22-2014, 01:01 PM   #22
edgooch
Motor mount and crossmember
Old 12-23-2014, 01:32 AM   #23
tommys72
tommys72's Avatar
looking good
Old 12-23-2014, 02:56 AM   #24
72 Copper C-10
72 Copper C-10's Avatar
I have a brand new power steering pump for a topkick hahaha
72 Copper C-10 is online now   Reply With Quote
Old 07-30-2016, 07:43 PM   #25
sdwolff98
Turning Wrenches Daily
Hey Ed,
Any more updates that is looking good!!!!!
Sean
Work! Play! Work work work! Money to play with. 64 GMC, 66 burb 4x4, and now 64 1ton money pits......ahhh life is good. Upcoming move back to Texas Dallas bound we are this september!!!
1964 GMC I1500 2wd (my baby) 8.1 allison 6 spd conversion Aka Smurf http://67-72chevytrucks.com/vboard/s...d.php?t=438342
2016 Ram Big Horn 4WD parts hauler
2010 Chevy HHR wife new car after the circled problem blew up!!!
1981 Ram D150 /6 auto Wife's sunday driver
Living outside Gladewater Texas now working in Longview at the hospital there
future project toys:
1966 Chevy K14 carryall aka Smurfette future project 283/auto overdrive http://67-72chevytrucks.com/vboard/s...d.php?t=551867
sdwolff98 is offline   Reply With Quote
1972, 4l85e, 8.1, fuel tank swap, np241
