1996 5 bolt rims on 1972 5 bolt
Hey all, this may have been asked at one point in time, but for my inspection I am not allowed to have my tires stick out over 1-1/2" of my fender. So my buddy has a good set of 5 bolt rims with stock tires from a 1996 GM 1500. It may be a stupid question, but will they fit correctly on my '72? I know that both bolt patterns are 5x5 but I just need confirmation that it will fit "correctly" and to save time finding them. Thanks in advance
Re: 1996 5 bolt rims on 1972 5 bolt
I wouldnt see any issue why they wouldnt fit.
1995 s10 blazer 4.3 1967 c10 350/350 fleet short 1993 s10 blazer 4.3l 4l60 RIP 6/20/14 2000 mercury sable Thats a how I roll |
Old member
The bolt pattern will be the same. The center of the wheels may be differant along with the off set of the wheel flange.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Moderator
![]() Join Date: May 2007
They should have enough backspacing to tuck inside the fender.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
Tags |
1972 c10, 1996 gmc sierra, 5 bolt, bolt pattern, wheels |
