Old 08-31-2014, 09:13 PM   #1
jstrong394
jstrong394's Avatar
Cab mount bushings
Going to replace the cab mounts while I do my cab swap. Who makes the best. I figure rubber over poly, but not sure. Also should I go ahead and get new hardware too?
jstrong394 is offline   Reply With Quote
Old 09-01-2014, 12:07 AM   #2
Your41Plague12
Your41Plague12's Avatar
Re: Cab mount bushings
Rubber will ride nicer than poly but won't last as long. I would definitely recommend getting new hardware as well, at least the bolts. If your cups are fine, go ahead and reuse them. I got my cab mount bushings through a local shop that deals in replacement panels for classic cars and trucks. If I remember right, they were way cheaper than LMC and they worked great. But if you can't find any locally, you may be stuck using LMC, Brothers, or Classic Parts. Check the vendors here also, they're great to work with and they can often get you a better product for a better price.
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
Old 09-01-2014, 12:29 AM   #3
jstrong394
jstrong394's Avatar
Unfortunately there isn't anything local other than the known chain stores. I looked at lmc and they had two different complete mount kits for 2 different prices. Assumed one was rubber other was poly. Plan to redo all mounts while I'm going to have everything loose. Definitely gonna get with the forum vendors before I order anything
Old 09-01-2014, 12:33 AM   #4
Your41Plague12
They also list it differently for 73-80 and 81-87. I would just get with one of the forum vendors, tell them what you have, and they'll hook you up with what you need.
Steve
Old 09-02-2014, 06:29 PM   #5
56pu
Was it PMP? I use them a lot. Ive been friends with the owner for years.
56pu is offline   Reply With Quote
Old 09-03-2014, 06:04 AM   #6
Your41Plague12
Sure is! Wow, someone local. I wish I still had my truck. Actually I wish I was still back in America. I'm stuck on this little island we like to call Okitraz (Okinawa) with the marine corps for a while.
Steve
Old 09-03-2014, 06:29 AM   #7
Skunksmash
Skunksmash's Avatar
How long do the rubber ones last?
Skunksmash is offline   Reply With Quote
Old 09-03-2014, 06:33 AM   #8
Your41Plague12
Well, that's hard to say. How long did they last before you deemed they needed replaced? If I had to make a guess, I'd say around 15 years at least.
Steve
Old 09-04-2014, 04:32 AM   #9
LS-K
Don't mean to butt into this thread or hijack, but what company is PMP? I've looked for a list of vendors and cant seem to find anything. Thanks.
LS-K is offline   Reply With Quote
Old 09-04-2014, 09:59 AM   #10
jstrong394
jstrong394's Avatar
I can't find anything on then either. Having a hard time finding a vendor with mounts on here
Old 09-04-2014, 12:04 PM   #11
Pro Performance
Pro Performance's Avatar
Just thought I would put a link to the Prothane poly ones we sell, which have a hint of graphite in the them for the black colored ones. I don't have a source for rubber ones, but Classic Parts would be a good source for rubber.
73-80
http://www.azproperformance.com/Prot...ab-Mounts.html
81-87
Pro Performance is offline   Reply With Quote
Old 09-04-2014, 02:59 PM   #12
Malo83
Cruzzzn' Vet
Malo83's Avatar
Depends on your location and weather conditions, here in Cali I still have the originals on my Silverado (31yrs) with no cab lean, misalignment
Malo83 is offline   Reply With Quote
Old 09-04-2014, 10:46 PM   #13
Your41Plague12
Parker Metal Products, in Tarentum, Pennsylvania.
Steve
Old 09-05-2014, 12:19 AM   #14
aotte1
I just purchased a set from GM a few months ago.
Les
aotte1 is offline   Reply With Quote
