Old 09-15-2014, 04:39 PM   #1
hotrod1
56 - autocross
hotrod1's Avatar
AC Vents - Sound Off!
What are you guys using for AC vents and where are you putting them (or where will you put them)? Pics would be great! Lets hear from all you great fab guys also.
hotrod1 is offline   Reply With Quote
Old 09-15-2014, 07:45 PM   #2
OrrieG
OrrieG's Avatar
Re: AC Vents - Sound Off!
VA system but I did not like the vents at all. For the under dash I modified the VA plastic to put the vents up higher (cut and flipped the bezel) then made a new grille out of polished aluminum with metalic black paint to match the steering wheel. I but 07 mustang vents in the kick panel with the courtesy light and speaker. I can adjust the under dash with a high tech popcicle stick, once they are set, probably will not move them. trial run with just the fan has plenty of air movement.
OrrieG is offline   Reply With Quote
Old 09-15-2014, 07:56 PM   #3
hotrod1
56 - autocross
hotrod1's Avatar
Wow, that is NICE!
Old 09-15-2014, 07:58 PM   #4
hotrod1
56 - autocross
hotrod1's Avatar
Orrie
Can you tell me what is the outside diameter of the chrome ring? I wonder if they are the same as the F150 vents?
Old 09-16-2014, 12:40 AM   #5
OrrieG
OrrieG's Avatar
I will check my thread, I know I had to modify them. I think they are the same as the F150 ones, that is what I was looking for when I found the Mustang ones. Found it look at this http://67-72chevytrucks.com/vboard/s...&postcount=905
Old 09-16-2014, 12:36 PM   #6
hotrod1
56 - autocross
hotrod1's Avatar
Anybody else?
Old 09-17-2014, 06:18 PM   #7
roger55
roger55's Avatar
These are from Vintage Air for 55-59 pickups:
They are billet aluminum bezels and they have many choices for the ball louver for them.
For the center vent, I'm just using the one that came with their GenIV kit.
roger55 is offline   Reply With Quote
Old 09-17-2014, 06:35 PM   #8
hotrod1
56 - autocross
hotrod1's Avatar
What a beautiful truck.
Old 09-17-2014, 06:59 PM   #9
roger55
roger55's Avatar
Thanks. I take it you looked at my build thread.
I'm not working on it right now because I'm involved with the building of an addition on my house. I'm hoping to get back on the truck in a few weeks. I figure it will take me 3 months or so to finish it.
I didn't know if you had a TF or AD so I'm not sure if what I did with those vents apply to you or not.
Old 09-17-2014, 07:06 PM   #10
hotrod1
56 - autocross
hotrod1's Avatar
I have a 56 but my build is opposite of yours. Autocross-pro touring. I sure do like a clean "stock" (at least compared to mine) truck though.
I just posted this because I dont know of all the options and have not seen many posts that address it. I think everyone can benefit.
Old 09-19-2014, 02:24 PM   #11
Oldchevypickup
Not the best picture but made a new panel for under the original dash that houses the radio, AC/heat controls and 4 billet vents.
Oldchevypickup is offline   Reply With Quote
Old 11-30-2014, 01:46 AM   #12
hotrod1
56 - autocross
hotrod1's Avatar
ANYbody else?
Old 11-30-2014, 03:27 AM   #13
oldman3
oldman3's Avatar
Just the standard VA rectangular ones in my lower panel on the AD, and rounds ones on Jimbo in dash and the console...Jim
oldman3 is offline   Reply With Quote
Old 11-30-2014, 10:17 AM   #14
torchlight
torchlight's Avatar
I was having a hard time finding a vent setup to put in my 53 that would still look like maybe it came from the factory that way. So many of the aftermarket vents out there look cool, but also modern and they stick out a little bit in an old truck, I think. Also, because the AD trucks have a curved dash, there's not really a natural spot for installing a vent that has a flat mounting face, as most vents do. My truck ended up with a custom flat valance piece under the dash, with recessed openings for the vents. I think the recessed openings really help to make it look like it could have been an original piece.
Build Thread: "Marvin" (1953 3100)
torchlight is offline   Reply With Quote
Old 11-30-2014, 10:21 AM   #15
magicoolbus
magicoolbus's Avatar
Here's mine. Stock V/A center vents, and modified side vents. Just used 2 1/2 hole saw and voila.
JB from AZ
1969 Chevy Sub K10
1957 Chevy 3200
1962 VW Beetle
1957 Willys CJ5
magicoolbus is offline   Reply With Quote
Old 11-30-2014, 01:13 PM   #16
hotrod1
56 - autocross
hotrod1's Avatar
That area of the dash has a compound curve. How did you account for the round vent having a flat mounting surface and the dash curved?
Old 11-30-2014, 01:23 PM   #17
hotrod1
56 - autocross
hotrod1's Avatar
Hey Torchlight. That piece looks great. What gauge steel ( it is steel isnt it) is it and how did you do the recess?
Old 11-30-2014, 02:23 PM   #18
magicoolbus
I picked the area with the least curve, if you look real close you can see that the bezel doesnt sit perfectly flat.
JB from AZ
1969 Chevy Sub K10
1957 Chevy 3200
1962 VW Beetle
1957 Willys CJ5
