Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 09-19-2014, 03:20 AM   #1
redsled87
redsled87's Avatar
Project lighten up front end
Without converting to a Mustang II type front end, what can I do to drop some weight. I plan on putting the battery in the bed this winter. I already got rid of power anything and the heater. The factory jack and the outer bumper brackets are history too. I also have 4" wide Centerline Convo Pros on the front too. Where in the suspension can I loose weight woithout spending a ton of money? This is on a '87 R10 with a bbc in it. Its. Race weight is 4010 with me in it and 60lbs of ballast in the right rear.Without the weight, 3950.
1987 R10 Pump Gas 496/TH375
Best 1/4 pass to date
60' 1.49
1/4 10.93
MPH 120
redsled87 is offline   Reply With Quote
Old 09-19-2014, 09:11 AM   #2
PGSigns
PGSigns's Avatar
Re: Project lighten up front end
If mostly race then the inner fenders can go. A glass hood drops a bunch. Loosing the carpet and padding and going to a rubber mat helps. Light weight seats. A glass bumper front and rear. Aluminum mirrors. 10 or 12 gallon fuel cell behind the rear end. Aluminum radiator. Spindles that use the 1" thick rotors. Exhaust that dumps at the back of the cab. No tailgate. No front sway bar. All this will get the weight down.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
