Oil pan cover plate
I just received my new engine and transmission, and have a question.
It's a 5.3 E-Rod connect and cruise package. It has the truck oil pan. On the bottom of the front part of the aluminum oil pan there is a thin sheet metal cover plate held on with some small bolts. What is that cover plate for? Thanks |
Re: Oil pan cover plate
here is a picture
Never seen that before, but it must be some kind of a heat shield from a certain application. Its odd that the part number on it is for a truck oil pan.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
the E-Rod package comes with that pan.
I'm going to keep it. It will hang a little low in my 53 pickup, but will still end up with about 7 inches of ground clearance. I'm planning a tubular skid plate for it. The bolt pattern on that thin plate is rather odd. It almost begs to be removed just to see what is behind it! |
![]() Join Date: Sep 2005
Im not sure butni see them on truck pans all the time at work don5 know what its for
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
Hollister Road Co.
#8 | |
Are the engines that "loose" ,what are they deadening at that location, the conn. rods!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
