Old 11-03-2014, 05:20 PM   #1
volleyballer13
volleyballer13's Avatar
5.3/4l80e help
Been lurking on here for a while trying to figure out what to do. I recently purchased a 1970 Blazer, factory 2wd, with the 307/350 combo. Attached a couple pics of how I bought it and how it looks now. I just purchased a 5.3 out of a 2005 Tahoe that had a 4l60 behind it. I didn't get the trans with the engine. I have a build 4l80 from another project that I would like to use behind the 5.3. My question is how difficult to put it with the 5.3 in the blazer? What do I need? Or should I go with a 4l60 since that is what was behind the motor originally? I have been searching, but get conflicting info or info that is about swapping from a 60 to an 80 and didn't know if that would apply since neither trans has been in the blazer. I know I may have to get my driveshaft shortened, and need to get the computer reprogrammed. All the stuff to do with converting to EFI, I understand, it is just about the trans. Any and all help would be greatly appreciated.
volleyballer13 is offline   Reply With Quote
Old 11-03-2014, 11:58 PM   #2
truckdude239
truckdude239's Avatar
Re: 5.3/4l80e help
You will have to add a second speed sensor to the harness and have the computer flashed for a 4l80e
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 11-04-2014, 12:11 PM   #3
littlevictories
Re: 5.3/4l80e help
yeah i think ^ that's the most legit way to swap
more info on that here: http://ls1tech.com/forums/automatic-...l80e-swap.html
here's some info from denmah's site
https://sites.google.com/site/sloppy...-ls/4l80e-info
i swear i have read about a swap that didn't require a segment swap in the computer, but hell if i can find that info now
littlevictories is offline   Reply With Quote
Old 11-04-2014, 01:40 PM   #4
656mx
Re: 5.3/4l80e help
I have a 80 behind my 5.3. Not a hard swap to do. Re pin trans plug, add vss, 6.0 crank spacer and bolts. I had to oblong the holes in 5.3 fly wheel for tork converter but i think you can use one from a 6.0 instead. I was going from a 400 to the 80 both were bolt on yoke so i just had to shorten my driveshaft 2 1/2 in. 80e trans segment swaped into pcm
656mx is offline   Reply With Quote
Old 11-04-2014, 02:37 PM   #5
volleyballer13
Re: 5.3/4l80e help
Thanks for all the info guys! When you say re-pin, you mean pull the wire from the wrong pin and insert into the correct pin, right? Just want to be sure. Was starting to get worried when I heard about people having to pull all the extra wires and basically rebuild the wiring harness.
On a side note, I thought I knew more about the EFI swap than I do I guess. I have been doing some reading and have determined that mine is a returnless efi system. So, does that mean I can use my existing fuel tank and just use a different sending unit that will have the correct pressure?
Thanks again for all the help. Also, if you know of a thread that will answer my questions without too much typing on your part, please point me in that direction. I just couldn't find the info I was looking for, or maybe I was asking the wrong questions.
Old 11-04-2014, 03:34 PM   #6
656mx
Re: 5.3/4l80e help
http://lt1swap.com/ has lots of good info and ls1tech.
Old 11-04-2014, 03:59 PM   #7
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: 5.3/4l80e help
If your just going to cruise in the Blazer, leave the 5.3/4l60e as a match, makes things easy. If your going to cam it or turbo, then the 4l80e is a better choice.
What are you using the truck for?
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 11-04-2014, 06:07 PM   #8
volleyballer13
Re: 5.3/4l80e help
Clyde65,
I am planning to mostly cruise it, but already have a cam for it. Goal is 400+ at the wheels. The reason I am wanting to go the 4l80 route is because I already have a built one, so don't have to buy a trans, and then have it rebuilt.
Russell
Old 11-04-2014, 06:08 PM   #9
volleyballer13
Re: 5.3/4l80e help
Thanks again, for all the info from everyone.
Russell
Old 11-04-2014, 09:12 PM   #10
68c10airstream
68c10airstream's Avatar
Re: 5.3/4l80e help
Hi Russell, i haven't paid a lot of attention on the 4l80 swap, but one item that i remember is a possible lack of room in the floor tunnel area. The trucks have a low hump and a high or tall hump. I believe the truck guys bolt in the high hump for the bigger 4l80. I assume the blazer has a removable trans hump. I'm running the factory low hump in my 68c10 with a 4l60 and its ok, close enough though. Great help on here, and some guys are modifying the stock tank for a add-0n low sump well area as a pick-up point for an external fuel pump i believe. Good luck, Brian Fuller
68c10airstream is offline   Reply With Quote
