Old 11-05-2014, 10:16 PM   #1
Roadkill58
Roadkill58's Avatar
Alternator Issues
I had an issue with an altenator and want to share with all of you.
The main wire on the altenator got loose and the connector was glowing red from being so hot (arcing).
I let it cool off and tried to tighten the nut. It decided to break off just as I thought it was tight enough.
I ended up with this after I grounded the end flat.
Notice the windings coming through the case. Not going to come off easy.
Name:  broken stud-1.jpg
I didn't have any metric nuts so I used a 5/16" nut drilled with a 17/64" bit and tapped with a 8-1.25 tap.
Name:  broken stud-2.jpg
I bought a 5/16" coupler? Drilled with a 17/64" bit and tapped with a 8-1.25 tap.
Name:  broken stud-3.jpg
Bought an 8mm bolt that is 1/2" long.
Name:  broken stud-4.jpg
Back in business.
Name:  broken stud-5.jpg
Rust Never Sleeps
Roadkill's 58 Chevy Stepside build
Roadkill's 69 Custom C20
Roadkill58 is offline   Reply With Quote
Old 11-06-2014, 12:23 AM   #2
mr48chev
mr48chev's Avatar
Re: Alternator Issues
As long as it works. It will give the rebuilder a "what the" some day after it dies but that's no biggie.
My ongoing truck projects:
Old 11-06-2014, 03:16 AM   #3
NEWFISHER
NEWFISHER's Avatar
Ingenuity. I like it!
GOD BLESS AMERICA!
NEWFISHER is offline   Reply With Quote
Old 11-06-2014, 05:54 AM   #4
Roadkill58
Roadkill58's Avatar
Thanks guys.
Just wanted to share a solution that could save someone some money.
The alternator is off of a 2004 Monte Carlo SS.
We are giving the car to a family member and I didn't want to spend more
money on it.
Rust Never Sleeps
Old 11-06-2014, 04:45 PM   #5
_Ogre
_Ogre's Avatar
necessity is the mother of invention
i like it
shop air compressor timer
Old 11-07-2014, 12:44 PM   #6
Roadkill58
Roadkill58's Avatar
Thanks Ogre.
Rust Never Sleeps
