Old 11-06-2014, 04:23 PM   #1
Nott32
47rh in c20?
I havent seen anyon e use this transmission in a swap but id like to save 2k and not buy an adapter and controller. If the nv 5 speed fits the 47rh should too correct? I undertsand i will need to get a custom drive line but at the very least it would a cheaper option. Any builds i missed or advice?
I have a 1st gen 12v
Thanks!!!
Nott32 is offline   Reply With Quote
Old 11-06-2014, 04:31 PM   #2
Got Smoke?
Got Smoke?'s Avatar
Re: 47rh in c20?
Lots of information on how to build a 47RH/RE on www.CompetitionDiesel.com user "Big Blue24" has very detailed and picture filled posts.
The 47RH is ideal in a conversion/swap because 1-3 are shifted hydraulically, and you can control TC lock up and over drive by toggle switches.
I'm currently trying to find a RH core to build and swap into my 97 Dodge in place of the NV4500, but the RH's are a little harder to find only being used for a couple of years vs the RE's.
97 Dodge 2500 12V NV4500... way to much to list.
79 Chevy K20 4" RC/37" GY OZ's 350/465/205.... restoration somewhere in the futue....
NEW: Project 88 Chevy R3500 3+3 / 88 V3500 3+3 combing two to make one....
Got Smoke? is offline   Reply With Quote
Old 11-06-2014, 07:24 PM   #3
clinebarger
Re: 47rh in c20?
Why not just use a 47RE/48RE? The electronics are stupid simple. And as a benefit the PCM will control the Alternator & Grid Heater.
The only major difference between the RH & RE is.... The RH uses a Hydraulic Governor, The RE uses Electronic Governor Solenoid & Governor Pressure feedback Sensor.
clinebarger is offline   Reply With Quote
Old 11-07-2014, 02:03 AM   #4
Got Smoke?
Got Smoke?'s Avatar
Re: 47rh in c20?
Because the RH doesn't require electronics or a PCM to work so its much cheaper to use.
Old 11-07-2014, 07:01 AM   #5
v-man
Re: 47rh in c20?
Dieselwrencher used the 47rh on my 89 GMC suburban. It's been working great. 2 manual switches 1 for overdrive 1 for torque converter.
v-man is offline   Reply With Quote
Old 11-07-2014, 07:51 PM   #6
clinebarger
Re: 47rh in c20?
OK, I was just throwing it out there, Though the PCM's are not that expensive, A PCM & harness can be had cheap from wreaking yards.
Old 11-07-2014, 10:20 PM   #7
patdaly
Re: 47rh in c20?
It is relatively easy to change the 91-93 A518 from a first gen Cummins into a 47RH. Better buy a few unloved ones, because as this gets out, they are going to go up.............
Enjoy.
http://www.dieseltruckresource.com/d...p-t318014.html
patdaly is offline   Reply With Quote
Old 11-08-2014, 01:53 AM   #8
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: 47rh in c20?
Thanks!!!
47rh's are in 94 and 95 V10 and Cummins trucks. 46rh's are in a lot of gas 360 and some 318 93-95 trucks. I've missed out on several 46rh's I would have baught for parts but didn't need them at the time. I have a 47rh in my wife's excursion, we put one in my Dad's 91 F-350, and I just put one in my Longhorn. I really like them. As far as the drive shafts, the 47rh ones will be shorter on the front and too long on the rear compared to a NV4500.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 12-04-2014, 06:42 PM   #9
Dieselwrencher
Re: 47rh in c20?
If you go with a 47rh, here is a really affordable controller I came across on another forum that may be the ticket for controlling these.
http://www.hgmelectronics.com/produc...s/csm-chrysler
Ryan
Old 12-04-2014, 08:38 PM   #10
72MARIO
72MARIO's Avatar
Re: 47rh in c20?
I tried that link its no good. I am interested in it if you could repost that link it would be great !
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 12-05-2014, 12:41 AM   #11
Dieselwrencher
Re: 47rh in c20?
Fixed the link.
Ryan
Old 12-05-2014, 05:57 PM   #12
gerfunken
gerfunken's Avatar
Re: 47rh in c20?
A friend of mine turned me on to these, saying that he's used them before and they work well.
http://www.bmracing.com/products/702...ue-converters/
-Scott
1972 Chevy K20
Picture Gallery
Build Thread
1930 Chevy AD
Picture Gallery
1929 Ford Model-A
Picture Gallery
1975 Triumph TR-6
Picture Gallery
Old 12-05-2014, 07:27 PM   #13
Dieselwrencher
Re: 47rh in c20?
That only controls lock up from what I'm seeing. You'd still have to do something for OD. It might work on an A518 though. Use the controller to operate the overdrive.
Ryan
Old 01-06-2015, 02:13 AM   #14
gerfunken
gerfunken's Avatar
Re: 47rh in c20?
He was planning on running two, one for the lockup, one for the OD.
-Scott
1972 Chevy K20
Picture Gallery
Build Thread
1930 Chevy AD
Picture Gallery
1929 Ford Model-A
Picture Gallery
1975 Triumph TR-6
Picture Gallery
Old 01-06-2015, 01:02 PM   #15
Dieselwrencher
Re: 47rh in c20?
Have you seen the compushift mini for the 47rh's now? I'll post a link later. They're only $350.
Ryan
