5.3 exhaust manifold questions
62 C10 frame, 78 c10 front end:
Looks to me like the stock 5.3 exhaust manifolds are too wide for the 62 c10 frame? I just removed the 5.3 from the donor and set the y-pipe into the frame of the 62. Do I need to use different exhaust manifolds? Or trim frame? Anyone done it to a 62? I believe the frames on 61-63 are different from 64-66? |
Re: 5.3 exhaust manifold questions
In the engine and drivetrain area there is a sub forum for LSX swaps. I believe from what I have read, the Trailblazer SS or Hummer H3 manifolds will work. Doug Thorley has a header that works too ( Shorty and mid, don't use the long) if you want to spend a few bucks more.
GOD BLESS AMERICA! |
![]() Join Date: May 2010
It only has original paint once |
#4 | |
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
here is the link to the LSx group.
http://67-72chevytrucks.com/vboard/f...play.php?f=206 as stated before, TBSS and Hummer mani's work best because they hug the block so well. I have Sanderson Shorty headers and I like them. there is also Doug Thorley long tubes also.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
60-66 Nut
![]() ![]() Join Date: Mar 2007
The '60-'62 have the X-member frames. The '63 was the first year of the ladder type frame. The frame shouldn't make much difference in what exhaust manifold to use. Where you may have issues is with the exhaust from the manifolds back.
