11-22-2014, 08:48 PM | #1 |
Louvered panels
I was thinking of adding these to the hood of my 64 GMC.
Mounting to the underside of the hood painted same red as truck with a thin polished aluminum trim ring on top. Opinions accepted. |
11-22-2014, 10:07 PM | #2 |
Re: Louvered panels
i think i would just have the hood louvered instead
11-22-2014, 11:30 PM | #3 |
Re: Louvered panels
It's your truck, do what you want and what makes you happy.
If it were mine, I would not do it. If your hood was not painted, or you have extra paint, I would do what xray said, have it louvered the correct way. I can tell you that when I was looking for a truck, I passed up a lot of nice trucks because of poorly done mods. Jim |
11-23-2014, 10:43 AM | #4 |
Re: Louvered panels
No. Get the real deal. Or the bilit 67-69 Camaro square ones might look better.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
11-23-2014, 11:19 AM | #5 |
Who Me?
Re: Louvered panels
Id pass... Looks kinda ghetto..
Steve 1997 Tahoe LT 4D 2WD (DD) 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
11-23-2014, 11:23 AM | #6 |
Re: Louvered panels
They look like floor heat registers.
11-23-2014, 01:08 PM | #7 |
Re: Louvered panels
11-23-2014, 01:11 PM | #8 |
Re: Louvered panels
hilarious is first thought, but really kinda true, ghetto.
benner Blacked out 1970 CST, C 20. Hardcore Work Truck with 350, Edelbrock 750, RPM High Rise, Flow-Masters, Black wheels and a Log Wood Rack. One Hot Worktruck. |
11-23-2014, 01:26 PM | #9 |
Re: Louvered panels
Maybe 69 camaro SS hood scoop inserts.... at least their GM..
1966 C10 SWB Fleet 5.3L LM7 Vortec / 4L60e Swap 1966 C10 w/ 5.3L/4L60e Build Thread 2012 GMC Sierra 5.3L 4x4 CCSB Last edited by 66LSx; 11-23-2014 at 01:31 PM. |
11-23-2014, 01:31 PM | #10 |
Re: Louvered panels
Just curious why do you want to add them for looks or are you having a problem with under hood temperature?
It only has original paint once Last edited by Mathew21; 11-23-2014 at 04:40 PM. |
11-23-2014, 04:29 PM | #11 |
Re: Louvered panels
Thank you 66lsx
You seem to understand the look I am after. Thanks for posting those photos. I may have been pre-mature posting my original pictures. The idea is to mimic the look of the Camaro vents with a narrow polished aluminum outer trim ring and rather then mesh on the inside go with the louvers. The pictures I posted were just to show where I intended to place them, same as the early Camaros. They would be painted black or the same red as the hood. I was planning on mounting the louvers to the underside of the hood with the trim ring lining the hole in the hoid, with no exposed fasteners. I wasn't planning on attaching with duct tape, large bolts or bent over spikes. WOW, tough crowd!! |
11-23-2014, 08:51 PM | #12 |
Who Me?
Re: Louvered panels
Now if this was sticking thru the hood, you would have some thing
11-23-2014, 09:01 PM | #13 |
1961 crewcab
Re: Louvered panels
here is the Camaro version:
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
