11-28-2014, 05:17 PM | #1 |
Good Trac Bar?
Since CPP & POL are having a 10% off sale and both these tracs are the same price, which is better?
CPP: http://www.classicperform.com/Store/...k/6062DTBK.htm POL: http://www.performanceonline.com/196...-Bar-Trac-Bar/ Also: 1. Will both of these fit my 1970 that I'm droping 5 inches with CPP springs? (Stock truck arms) 2. Which has better shipping rates? Or is it the same?
"Sometimes I do serve as a good bad example. Glad to be of service." My Build Thread (1967 C10, lowered, EFI, daily truck): http://67-72chevytrucks.com/vboard/s...d.php?t=830809 |
11-29-2014, 12:11 PM | #2 |
Re: Good Trac Bar?
Looks like the POL version is CPP's original single adjustable bar. Their newer version is adjustable on both ends. The only thing I'm not sure of is if the dbl adjustable bar is Left-hand/Right-hand thread or both Right-hand.
The LH/RH thread combo is the ticket as you can adjust the center w/o removing the bar (like a tie-rod end).
11-29-2014, 04:22 PM | #3 |
Re: Good Trac Bar?
So CPP seems to be way to go?
11-29-2014, 07:24 PM | #4 |
Re: Good Trac Bar?
didnt get the deluxe one but just got mine from brothers trucks ,cheapest i could find it has left hand threads on one end and right on the other
12-05-2014, 07:53 PM | #5 |
Re: Good Trac Bar?
The deluxe POL bar is double adjustable with lh/rh threads
06-07-2016, 10:43 PM | #6 |
Re: Good Trac Bar?
Gonna be ordering a POL rear trac bar. Just wondering the difference between these two and which one you recommend for my setup? I have a 1968 with 4' rear drop springs in the rear, with 2' drop blocks, and shock relocators.
https://www.performanceonline.com/19...onversion-Kit/ http://www.performanceonline.com/196...-Bar-Trac-Bar/ |
06-07-2016, 11:45 PM | #7 |
Re: Good Trac Bar?
They're both the same. One kit is a conversion kit for a non-truck arm app.
06-08-2016, 10:41 AM | #8 |
Never Ending Projects
Re: Good Trac Bar?
Early Classic Enterprise is my recommendation. I have had it and the CPP one. Of the two I liked the ECE one better. CPP made the hole on the trailing arm bracket too close to the vertical part of the bracket and I can't get a wrench/socket on to tighten it. I am going to swap the bolt out for a flange bolt which will have a smaller head hex.
I just had a buddy install the ECE this past weekend and it went in perfect.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
06-08-2016, 05:37 PM | #9 |
Re: Good Trac Bar?
If you need U-bolts, another bonus with the ECE is the longer U-bolts are included.
Tags |
5 inch drop, cpp, panhard, pol, trac bar |
