Old 11-29-2014, 05:46 PM   #1
lowlyfec10
cpp stands/mounts/sliders
does the motor need to be perfectly centered and level to get both of the long mount bolts to line up or am i just a lil retarded? lol driver side sets down and can get the bolt through but the passenger side bottoms out about an inch above the hole -_-
lowlyfec10 is offline   Reply With Quote
Old 11-30-2014, 08:46 PM   #2
joey8383
joey8383's Avatar
Re: cpp stands/mounts/sliders
I ran in to this too. Check out my build thread. I ended up having to mill my adapter plates down to about 5/16" or a tad less. Don't waste your time calling CPP. I wasn't using their adapter plates and mine were 3/8" thick to start with. Mine aren't sliders but are the Ebay 3 position plates. Pretty sure all this is in my build thread "His 1969 stepside build" . Let me know if you can't find it.
joey8383 is offline   Reply With Quote
Old 11-30-2014, 08:48 PM   #3
joey8383
joey8383's Avatar
And be sure to grind the hump down on the back of the motor mounts if it has a ridge running right down the middle! Get the back of it flat.
Old 11-30-2014, 08:56 PM   #4
elimontfort
elimontfort's Avatar
I didn't have that problem but my motor was 1/2 inch off on the drivers side to the passenger side. I had to break all the mounts loose after I hung the transmission and pull the motor over and tighten it all back down. Also there swap cross member for the transmission wouldn't fit. I had to use my 700r4 cross member from bowtie over drives. Not really impressed with cpp right now.
elimontfort is offline   Reply With Quote
Old 12-02-2014, 10:38 AM   #5
lowlyfec10
cool joey, i'll look into it.
and you're runnin the same exact setup elimontfort?? i still have the same th400 trans member so we shall see how it lines up after...im just worrying about the motor for the time being.
Old 12-02-2014, 11:40 AM   #6
elimontfort
lowlyf same set up as what? im doing a lq4/4l80 swap now. I had a 350/700r4 before.
Old 12-02-2014, 11:59 AM   #7
lowlyfec10
as in the cpp swap stuff.....the stuff my post is asking about lol
Old 12-02-2014, 12:54 PM   #8
elimontfort
Ok got it. No I didn't have that problem just the problem I stated. Are you running the full swap kit from cpp? if you are do like joey said and make sure the rubber mounts are sitting flat against the adapter plates. The mounts have a hump in them that needs to be notched for the adapter plates. in my case I had to grind that hump all the way down.
Old 12-03-2014, 12:56 PM   #9
joey8383
joey8383's Avatar
Check out his build thread. They sent him motor mounts that look like solid motor mounts but I think there is some rubber in there, but it's nothing like a typical motor mount. And there's a metal plate behind the motor mount. He's going to toss the metal plate and just bolt the motor mounts to the sliders.
Surely somebody has ran this CPP set up. Brian?
I only did CPP stands and then used typical GM car motor mounts 1959-1970's, and then some Ebay 3 position adapter plates that I had to mill down to just under 5/16" thick.
Old 12-03-2014, 01:58 PM   #10
elimontfort
I'm using the whole swap kit from cpp it came with the perches the mounts and the adapter plates. The mounts are like you said the rubber ones with the backing plates like the old sbc mounts. I didn't have to mill anything down just ground the humps off the sbc mounts and it all went in level.
Old 12-03-2014, 06:33 PM   #11
lowlyfec10
yeah, i have the cpp sheetmetal stands, poly mounts, and slider adapter plates.....my mounts had no humps however
Old 12-04-2014, 04:13 PM   #12
chevyguy_72
Vintage Evil
chevyguy_72's Avatar
I have the same problem on mine... off just enough the bolt wont slide in...
Current Rides:
Vintage Evil - 72 Chevy C10 (Always a work in progress) Vintage Evil Build Thread
EvilK5 - 71 K5 Blazer
Evil Twin - 2006 Suzuki M109R
EvilDmax- 2018 GMC 2500 Denali Duramax
chevyguy_72 is offline   Reply With Quote
Old 12-10-2014, 11:29 AM   #13
lowlyfec10
i'm going to remove the plate that came with the poly mounts and retry. pretty sure i should be ok then. couldnt test fit this past weekend due to crappy weather...will try again this weekend.
