12-05-2014, 08:17 PM | #1 |
1970 c20 misc. small parts
Some parts leftover from a '70 c20
Washer fluid bottle $10 Four-core radiator top brackets $5 Green seat belts $10 Horn $5 Front cab mounts & bolts $15 Rear cab mounts & bolts $15 Green Visors, no rips $20 Last edited by TheBreeze; 12-10-2014 at 03:46 PM. Reason: Dropping the prices |
12-05-2014, 08:25 PM | #2 |
Re: 1970 c20 misc. small parts
Gauge cluster Sold
2bl air cleaner spacer $5 C/20 emblems $10 Rear shock mounts $10 Gas pedal Sold Emergency brake pedal assembly $20 Brake pedal assembly $25 Last edited by TheBreeze; 12-10-2014 at 03:47 PM. |
12-05-2014, 08:35 PM | #3 |
Jack w/ mounting hardware $20
Vent arms $5 Wiper arms, no pitting $ Sold Half a gunrack $5 Ground straps, useable $1 Doorhinge hardware $6 Last edited by TheBreeze; 12-10-2014 at 03:47 PM. |
12-05-2014, 08:45 PM | #4 |
Over load springs 3/4 T $20
Passenger mirror $5 Breather tube $2 Wiper arm linkage $5 Column mounting bracket $2 Hood Latch bracket w/bolts $5 Front bed brackets $5 Last edited by TheBreeze; 12-10-2014 at 03:48 PM. |
12-05-2014, 08:59 PM | #5 |
How are the overload spring mounting brackets for rust? The pair I have are a little rough.
Thanks, Paul |
12-05-2014, 09:05 PM | #6 |
Low-hump center firewall padding $ Sold
Dirvers side firewall padding $ Sold Last edited by TheBreeze; 12-05-2014 at 11:24 PM. |
12-05-2014, 09:13 PM | #7 |
Bolt/retainer/spring kits
Prices vary $2-$5 Last edited by TheBreeze; 12-10-2014 at 03:48 PM. |
12-05-2014, 09:16 PM | #8 |
Alternator $15
Headlight buckets $5 Rear emergency brake cable w/ linkage, will be seperated from frame members $25 Turbo 350/400 Auto linkage w/ bracket $30 Last edited by TheBreeze; 12-10-2014 at 03:49 PM. |
12-05-2014, 09:22 PM | #9 |
Ill take the 3/4 ton overload springs depending on the cost of shipping.
How much to 91011 |
12-05-2014, 09:23 PM | #10 |
Misc. trim, straight $3 ea
OEM hoseclamps 3/69 1-3/16 $5 ea Exhaust hanger $3 Relay, working $2 Side marker $1 Last edited by TheBreeze; 12-10-2014 at 03:49 PM. |
12-05-2014, 09:27 PM | #11 |
I will take the wiper arms depending on shipping to Ga 30114 .
12-05-2014, 09:41 PM | #12 |
Paul - It's surface rust, they will end up with some pitting. I can sandblast them if needed.
12-05-2014, 09:53 PM | #13 |
If you could get me some better pictures I would appreciate it. My email is 2paulstreet@gmail.com
Thanks, Paul |
12-05-2014, 10:03 PM | #14 |
Sent
12-05-2014, 10:20 PM | #15 |
I will take both. LMK total shipped to 78602
1971 Bone Stock C10 project "Jake" 1997 Sierra SLT factory short bed "Silver Bullet" |
12-05-2014, 10:25 PM | #16 |
Paul - $15
12-05-2014, 10:32 PM | #17 |
I'll take the overloads. Do you happen to have the plates with rubber bumpers off of the trailing arms? My zip is 84043 let me know a total and how you want to be paid.
Thanks, Paul |
12-05-2014, 10:41 PM | #18 |
Which Paul? BlueK5 or me? If $15 is the shipping cost for the firewall pads then the total would be $50 which is acceptable. PM payment info?
12-05-2014, 10:41 PM | #19 |
In line on the overloads if all falls through.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
12-05-2014, 10:56 PM | #20 |
As agreed, $35 for firewall pads plus $15 shipping. I added 3% to cover PayPal fees as required by PayPal and http://67-72chevytrucks.com/ forum rules: We do not send payment for goods as gift.
Thanks! Paul.
12-05-2014, 10:59 PM | #21 |
Olive glove box door $25
Bed trim $5 Fender trim $ free Door hardware cups $ free Window crank, good cond. $3 Door handle, good cond. $3 Trim retainers (more than shown) $ free Vent window $15 Fan shroud $30 Last edited by TheBreeze; 12-10-2014 at 03:50 PM. |
12-05-2014, 11:57 PM | #22 |
Bed trim $1
Window crank $3 Armrest, olive green $10 Armrest, cracked/broken corner $3 Passenger fender, front corner seam has separated $75 shipped Last edited by TheBreeze; 12-10-2014 at 03:51 PM. |
12-06-2014, 03:59 PM | #23 |
Door panel $10 each
Top trim, painted $5 both Last edited by TheBreeze; 12-10-2014 at 03:51 PM. |
12-06-2014, 04:16 PM | #24 |
Any luck on shipping quote on the overloads? Paypal?
12-06-2014, 04:36 PM | #25 |
Bluek5 - $35 shipping for the bumps and springs, $25 for the bumps (they still need to be cut off)
