Old 12-12-2014, 09:21 AM   #1
David623
Exhaust manifold; vent check valve
I have put a 1999 5.3 Silverado engine and trany into a 1972 Jimmie. From what I see the existing exhaust manifolds will not work without modifying the frame, from research on this website Trailblazer, Corvette, Camaro manifolds will work which is the best choice? Also I am dealing with relocating the A/C compressor, Kwik performance I think has that problem solved, sent them an email for more information. And finally I have put an Aeromotive fuel pump in the new gas tank I need to find a check valve to complete the fuel line.
I will post some pic soon, just put the rebuilt tub back on the frame.
David623 is offline   Reply With Quote
Old 12-12-2014, 08:52 PM   #2
cableguy0
Re: Exhaust manifold; vent check valve
im going to move this to the Ls swap section to hopefully get you some answers.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 12-12-2014, 09:56 PM   #3
truckdude239
truckdude239's Avatar
I used trailblazer ss manifolds they cleared good fuel pump should have built i. Check vavle
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 12-15-2014, 03:28 PM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
What do yo need a check valve for? Are you wanting something like a rollover valve? The pump itself "holds" as much pressure as needed, you don't need a 1-way valve on the fuel system.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 12-15-2014, 07:11 PM   #5
David623
The check valve is for the fuel system, I installed an Aeromotive fuel pump in the new gas tank and there is a supply, return and a vent connection on the pump And I assume it is to prevent a vacuum and not let the gases from the tank to get out.
Old 12-15-2014, 07:37 PM   #6
David623
Here is a shot of the new tank and fuel pump installed.
Old 12-16-2014, 02:07 AM   #7
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
OH you mean on the evap line? My bad, I thought you wanted a check valve in-line with the actual feed or something.
In that case, I've seen a few different things used. You can get away with nothing, but a breather or a PCV (ball-check) will work as a low buck solution.
Old 12-16-2014, 03:42 AM   #8
scottybaccus
scottybaccus's Avatar
I just left the evap canister connected to the tank.
I used the Hooker cast iron manifolds. They support 500 HP, and fit way better than any stock manifolds I've tried.
Scotty Baccus
scottybaccus is offline   Reply With Quote
Old 12-16-2014, 10:45 AM   #9
KEWLKATDADY
Is that a suburban tank?
1967 C10 custom
KEWLKATDADY is offline   Reply With Quote
Old 12-16-2014, 10:53 AM   #10
David623
I pretty sure the tank is the same for the Suburban and Jimmy, I got mine from LMC and they list is for both. I do have to modify the tank spout a little it wasn't same as the old tank.
